explodes coolant - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2008, 01:11 AM   #1
88mudder
In the band!
Default explodes coolant
302 v8 with foxbody mustang 3 core radiator. Whenever i drive the truck and shut it off it will explode coolant out the cap for a few seconds then stop...13 psi cap not sure what psi cap is needed, am i off?
Old October 28th, 2008, 02:13 AM   #2
Daniel
SFA Ranger
Daniel's Avatar
Maybe your cap is junk, they do go bad.
Go and get a good one, not one of the ones with the stupid lever thing.
Daniel is offline   Reply With Quote
Old October 28th, 2008, 01:43 PM   #3
88mudder
In the band!
i have a mustang radiator and from what ive read they use a 16 psi cap and the cap on there now is a 13psi..
Old October 28th, 2008, 04:35 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the cap is low for the usage. it should be a 15-18 and the antifreeze sould read -30* on a tester. if its higher or lower you will have issues. it maybe the block has a trapped air bubble also.
Yetti
Old October 28th, 2008, 05:16 PM   #5
88mudder
In the band!
i just picked up a 16 psi cap so ill try that out, im sure that my old cap was the culprit. I read the application guide for the 16psi cap and it shows for all 302v8's so thats what i got.
Page generated in 0.14019 seconds with 38 queries
