explorer trans options???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2008, 07:37 PM   #1
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
Default explorer trans options????
have a 92 explorer with a auto trans. wondering if theres any other options besides a stick for a swap. are there any kits or adapters for a c6 or anything out there??
lososjoyride00 is offline   Reply With Quote
Old October 27th, 2008, 07:49 PM   #2
Bones
Bones's Avatar
yes, search www.explorer4x4.com
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 27th, 2008, 08:41 PM   #3
i have seen a 700r4 swap
Old October 27th, 2008, 09:36 PM   #4
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
what about the c4 or whatever that auto is sitting in your backyard lol. that would fit wouldnt it?
muddywater is offline   Reply With Quote
Old October 28th, 2008, 01:44 PM   #5
chris1044
chris1044's Avatar
bolt up to the 4.0: M50D-R2 (don't bother with any other stick), C5 (very rare - hard to find flex plate), newer 5r55e (fully electric A4LD in a nut shell)
After market: Advanced adapters makes a 700r4 kit, and IIRC someone over on RRORC.com was making an adapter kit for virtually any transmission you wanted.....and, raptor transmissions makes a "high strength A4LD," though that's like an oxymoron....
Basically, the cheapest option with strength is the M5OD - they'll take quite a beating....swap isn't bad either if you get all the components from a donor truck, and even the pedal goes in easily
Old December 2nd, 2008, 12:44 PM   #6
deathbypsi
Brian R.
deathbypsi's Avatar
I am concidering a C5 behind a 4.0 myself. I have a rebuilt C5 witha 2.8 bell on it now, whats the deal with the flywheel and bell for this swap?
Old December 3rd, 2008, 09:39 PM   #7
Jdc215
Jdc215's Avatar
do the m5od-r1 and m50d-r2 have the same bell housing bolt pattern? are there variations?
Jdc215 is offline   Reply With Quote
Old December 3rd, 2008, 09:47 PM   #8
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
R1 comes in housings for the 4.0L V6 (and technically 2.9L V6) as a set, and I believe the 2.3/2.5L and 3.0L are interchangeable (don't quote me on that).
The R2 is for a fullsize, and I think that it only comes in he SBF pattern.
Both trannies have integral cast bells.
Old December 3rd, 2008, 10:03 PM   #9
Jdc215
Jdc215's Avatar
i knew the applications and that the bell housing is part of the trans but i didnt know if, as mentioned in an erlier post, if a m5odr2 could be bolted to a 4.0 or a 2.9 which are the same bolt pattern i believe. maybe it was just a typo. i know the R2 is stronger and if its posable to bolt in the stronger trans later i would as i happen to hav one.
Old December 4th, 2008, 01:02 AM   #10
Captain Ledd
Ranger Addiction?
Unless you use an adapter for the 4.0L to the SBF pattern, the R2 won't fit.
The 4.0L and 2.9 are the same pattern, but not the SBF pattern.
Page generated in 0.28836 seconds with 53 queries
