booty fab - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2009, 06:40 PM   #101
0Toncaddy
Big Belly Customs
0Toncaddy's Avatar
just picked up this gem of a parts truck from a guy, heres a few pics of the "fix" on the rear spring hangers
[IMG]http://i495.photobucket.com/albums/rr319/1toncaddy/bootyfix.jpg[/IMG
0Toncaddy is offline   Reply With Quote
Old January 2nd, 2009, 06:55 PM   #102
curt1656
Praise the lowered
curt1656's Avatar
Originally Posted by DUNE JUMP View Post
Redneck tube notching
Gotta love the welds at 4:40
Priceless.
Old January 2nd, 2009, 08:12 PM   #103
Fraser
Fraser's Avatar
Originally Posted by Ready4Wheelin View Post
Later model XJ's don't have a downstream O2 sensor=no check engine light. I don't have a cat on mine and never had a problem.
96 on they have, at least the old one my cousin had, the one i have and misc. other ones are just oddballs, my cousin and my buddy took cats off and they threw constant codes b/c of the downstream sensor. had a massive power loss, and had the light on all the time
Old January 16th, 2009, 07:28 PM   #104
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
Diesel pulling guys arn't the best fabricators.
Here is the rest of the thread I got that from http://www.thedieselgarage.com/forum...read.php?t=323
Old January 16th, 2009, 11:01 PM   #105
DUNE JUMP
DUNE JUMP's Avatar
those welds are HAWT
Old January 22nd, 2009, 08:50 AM   #106
DUNE JUMP
DUNE JUMP's Avatar
It's for sale!!
Old January 22nd, 2009, 08:53 AM   #107
DUNE JUMP
DUNE JUMP's Avatar
I can't believe I missed this, or that it is on the road. In his defense, it was probably a grade 8 exhaust clamp
Old January 23rd, 2009, 11:30 AM   #108
Brods
Ok someone is going to have to explain to my dumb ass why this is considered booty fab.
Now this is without doubt booty fab of the highest order. Not only is it structurally unsound, it goes the extra yard by being a critical suspension component likely to cause complete loss of control when it fails. Id love to see a slow motion video of that setup doing a panic stop. Would the radius arm crossmember just flex backward or would it collapse or would it tear completely off? Makes you wonder what the steering looks like.
It's for sale!!
Old January 23rd, 2009, 12:22 PM   #109
DUNE JUMP
DUNE JUMP's Avatar
Originally Posted by Brods View Post
Now this is without doubt booty fab of the highest order. Not only is it structurally unsound, it goes the extra yard by being a critical suspension component likely to cause complete loss of control when it fails. I’d love to see a slow motion video of that setup doing a panic stop. Would the radius arm crossmember just flex backward or would it collapse or would it tear completely off? Makes you wonder what the steering looks like.
I think I read the steering wasn't done, it still had to be "fabbed up". We should all be glad it wasn't "fabbed" by the same guy! No street sign, trampoline, or scaffolding within a 50 mile radius would be safe.
Old January 23rd, 2009, 01:26 PM   #110
Brods
Bracket welded to bracket bolted to bracket, welded to frame. It doesn't look like it would fail, but dang, at a certain point you have to look at the design and realize you should re-do it. AHHHHH!
Humm...not what I see. Bracket bolted to frame. Frame bracket modified with bolt on diagonal supports to allow ebrake cable to pass through. Shackle set up to allow front to back movement of the axle to prevent suspension bind while still controlling axle wrap. Quality hardware (grade 8 bolts) and a relatively sound design. Sure the frame bracket could have been executed a bit better and the fab work is not as finished as some more detail orientated fabricators would have done (ie rounded corners, etc.)..... and the welds could look better.....but booty fab? On a scale of 1 to 10 where that heep is a 9+ this has to rate a 1 or less.
Old January 25th, 2009, 06:13 AM   #111
VonDirt
VonDirt's Avatar
i like the idea of a rate or scale system.
most are familar with the "F" rating for tornados, so given theres carnage, danger, and ugliness involved it kinda fits. id suggest four measures -
1. idea
2. design/engineering
3. fabrication/craftsmanship
4. finish
an F4 would have failed on all counts, an F1 would fail on any one count etc.
VonDirt is offline   Reply With Quote
Old January 25th, 2009, 10:32 AM   #112
Yota Bill
1. idea
4. finish
sounds like a good rating system to me, but can you define those some? for example, you have "idea" as one, and "design" as the second one...whats the difference?
I'd like to know how often I build an F1 or a F2
Old January 25th, 2009, 11:11 AM   #113
JDirt
Always right-sometimes
JDirt's Avatar
Driving a Yota is an automatic F1.
J/K
JDirt is offline   Reply With Quote
Old January 25th, 2009, 11:17 AM   #114
DUNE JUMP
DUNE JUMP's Avatar
1. idea
4. finish
I love it-
I think the idea relates to the general concept being attemted, ie: traction bar, new steering setup, etc whereas the design/engineering is how well it is thought out and executed. Something like a wristed axle setup could be a nice idea, but be poorly designed, fabricated, and finished, and score an F3.
I think that XJ radius arm bracket definitely scores an F4. Bad idea, designed after too many beers, horribly fabricated (it gets weaker the closer you get to the frame rather than the other way around), and very much unfinished.
Good post VonDirt
Old January 25th, 2009, 11:52 AM   #115
Yota Bill
J/K
well, everyone is entitled to thier own opinion...not my problem if yours is wrong
Old January 25th, 2009, 12:06 PM   #116
JDirt
JDirt's Avatar
No sense of humor huh? If it makes you feel better, I'd say my Jeep is at least a F1.5
Old January 25th, 2009, 01:17 PM   #117
VonDirt
VonDirt's Avatar
Dune Jump hit the nail on the head - couldnt have said it better -
I love it-
Good post VonDirt
thanks man
Old January 25th, 2009, 02:22 PM   #118
Yota Bill
notice the ...if I was serious, I wouldnt be on the net...
besides, I dont even have a working (or assembled) Toy at the moment...I drive a Geo Tracker....
the name came about because someone that runs a different forum couldnt spell my last name, so he just changed it to that, and its stuck since then...
Old January 25th, 2009, 02:26 PM   #119
Yota Bill
thanks man
so if someone has the "idea" to build a bumper (for example) there is 1 point to the good? just because they decided to build it rather then buy it? I guess thats the one I dont understand...
*not trying to be an ass here, I just dont understand your meaning...
Old January 25th, 2009, 03:18 PM   #120
VonDirt
VonDirt's Avatar
yea, i see what your saying -
id say its about some mix of concept and or application. using your example, a bumper would score nothing in terms of "idea" because there is no idea/concept to it - its just execution. so the worst it could be is an F3.
but, if you wanted to use the volume within the bumper to brew beer, that would qualify as an idea. so - as soon as you wheeled it, it would foam up, vent, and blow like a volcano leaving you with nothing. and theres yer F4
Page generated in 1.18326 seconds with 84 queries
