36x12.50 15 TSL Bias Grooved
mounted on 15x8 5x5.5 $600
I bought them off another member who had them mounted on beadlocks. I know the very inner lip of one or two have the that very inner edge cut (on the bead) they do not loose air and do not effect the tire at all. One tire has a plug/patch in the center of the tread from a roofing nail. They have lots of tread. I'd keep them but i do not want to grind the D60 brakes to clear 15" rims and i want to gain ground clearance back from going 60's with larger tires.
3 measure 21/32nd in the center of the tread and 22-23/32nd on the outside
1 measures 19/32nd in the center and 21-22/32nd on the outside
using an actual tire tread depth gauge
this is the tire with all the rash
Middleville, MI would be willing to drive "some" distance
