tail lights not working - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2008, 11:02 PM   #1
88mudder
In the band!
Default tail lights not working
84 Ranger with a 302v8. I was driving down the road at night and then my tail lights go out as well as the front sidemarker lights. I get home and the fuse is blown on that circuit, i knew thats what happened. 15 amp fuse, everytime i try to put a new fuse in it keeps blowing. Could i have a short somewhere? It was raining when this happened.
Old October 25th, 2008, 12:07 AM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
check and see if you have a wire exposed and maybe it got wet and keep shorting it out
Bronco Ollie is offline   Reply With Quote
Old October 25th, 2008, 12:09 AM   #3
88mudder
In the band!
thats what im thinking. Gonna try it tomorrow after the truck dries out, that way ill know if a wire got wet and shorted.
Old October 25th, 2008, 12:11 AM   #4
Bronco Ollie
yeah just trace all the wires back
Old October 29th, 2008, 07:14 PM   #5
88mudder
In the band!
i looked and couldn't find anything on the wires. I checked all the fuses and just the 1 for that circuit is blown. Im not much of an electrical guru, any tips on what to check for? I put a meter up to the light sockets and the needle pegs to 0..whats this mean?
Old October 29th, 2008, 08:13 PM   #6
HarleyKing
It's a fuse. The dashboard lights and the taillights are on the same circuit intentionally. The reason for this is to give the driver an indicator that the taillights do not work.
HarleyKing is offline   Reply With Quote
Old October 31st, 2008, 09:13 AM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
Do you have a trailer harness on it? I had a shorted trailer harness do thay on my F series, the wires got pinched between the bumper and the hitch.
Old November 4th, 2008, 04:33 PM   #8
88mudder
In the band!
Didn't find anything, searched the entire tail light harness from back to front. Checked trailer harness as well. The headlights work , but everything else on that fuse doesn't. Any more help?
Old November 5th, 2008, 08:11 AM   #9
fsumotorhead
N8KVB
use a piece of metal instead of a fuse, look for smoke, when you find the source of the smoke you have found the problem area
all joking aside, do you happen to have a wiring diagram?
Old November 9th, 2008, 09:31 PM   #10
mudbillyredneck
mudbillyredneck's Avatar
I've done that before...only to find out it was a bad wire...LOL
mudbillyredneck is offline   Reply With Quote
Page generated in 0.31729 seconds with 53 queries
