Alignment after trackbar? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2006, 10:12 AM   #1
SS
Bananarama!
SS's Avatar
Default Alignment after trackbar?
After I replace my track bar do I need to get a front end alignment?
1995 Dodge Ram 1500 4x4 5.2L
-Jer
Old May 5th, 2006, 10:18 AM   #2
PavementPounder
PavementPounder's Avatar
If its a stock replacement, your wheel alignment should not have changed. If its a non-stock unit or an adjustible one, you may have to re-center your steering wheel (adjust draglink) if it lets the axle shift cross-car.
Old May 5th, 2006, 12:22 PM   #3
sonic
sonic's Avatar
Its a good idea anyways although as stated before probably not nessesary. Depending on how bad it was if it was replaced because it was a problem component it could have thrown off other components as mine did when it started to cause a serious "death wobble". It definently wont hurt.
sonic is offline   Reply With Quote
Page generated in 0.15668 seconds with 32 queries
