explorer dana 44 front swap??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2008, 07:00 PM   #1
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
Default explorer dana 44 front swap???
i have a 92 explorer, with a trashed TTB front axle, i have a 79 straight 44 out of a bronco, been measuring and found that the radius arm brackets are gonna go right where my tranny crossmember bolts on. whats the easiest fabrication, or any other tips for this swap would be helpful. also have a 9 inch rear thats goin into this.
lososjoyride00 is offline   Reply With Quote
Old October 22nd, 2008, 10:41 PM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
the swap is not hard look at cheapthrillb2 build are you going to run leafs or coils in the front?
Bronco Ollie is offline   Reply With Quote
Old October 23rd, 2008, 01:59 PM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
build a new cross member with the radius arm mounts attached.
Are you narrowing it?
Old October 24th, 2008, 06:19 PM   #4
lososjoyride00
nope, full size. and running coils.
Old October 24th, 2008, 07:43 PM   #5
88mudder
In the band!
ditch the factory crossmember. You can fab one up easily, flat steel and drill holes. This makes so the radius arm lays up against it flat under the frame.
Old October 27th, 2008, 08:18 PM   #6
lososjoyride00
almost done already, all i did was swapped radius arm brackets from side to side, and turned them around backwards. still used the stock crossmember. just need shocks and brakes and the fronts done. then on to the 9 inch rear.
Old October 27th, 2008, 08:32 PM   #7
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
i would have built longer arms. those stock arms are gonna suck for flex. when we put my dads together we did 13 in longer than stock 79 arms. didnt have to mess with the crossmember, used the 79 radius arm brackets, and got more flex in the meanwhile.
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old October 27th, 2008, 08:36 PM   #8
lososjoyride00
we'll see what happens, if i have problems, we'll take the torch to them. thanx.
Old October 27th, 2008, 09:23 PM   #9
alboy79
alboy79's Avatar
have ya got any pics of how shes lookin? what coils did ya go with?
Old October 31st, 2008, 09:21 PM   #10
lososjoyride00
used coils that were in it. 4 inch rough country. worked great.
Old November 4th, 2008, 02:12 AM   #11
Pete M
Comanche Addict
Pete M's Avatar
I'm running factory Ford arms under my MJ and it's not the arms that sucked, it was the poly C-bushing I first used. They were horrible! I went back to the stock rubber bushings and the truck maxes out the flex it can have (considering the stock flares and shock length). I've got some longer shocks now and can't wait to see what she'll do.
--Pete
Pete M is offline   Reply With Quote
Old November 4th, 2008, 06:26 PM   #12
lososjoyride00
ill try to get some pics.
Old November 9th, 2008, 08:51 PM   #13
lososjoyride00
Old November 9th, 2008, 08:52 PM   #14
lososjoyride00
on 36 inch swampers, didnt turn out too bad. 44 front and 9inch rear. possible 4.88s and lockers all around next weekend. too much fun to be had.
Page generated in 0.32720 seconds with 65 queries
