no more ranger, got traded - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2008, 12:11 AM   #41
98-S10-lifted
98-S10-lifted's Avatar
I think I am going to start gathering parts for a solid axle because I am not completely happy with the way that it is.
98-S10-lifted is offline   Reply With Quote
Old November 27th, 2008, 07:31 PM   #42
98-S10-lifted
update... my truck sucks. who woulda figured with it being two wheel drive ;D
So it is now a for sure thing, I AM doing a solid axle. The amount of lift will depend on the size tires I can find in the classifieds on here, , or Craigslist.
I now remember why I sold my 2wd lifted S10... it couldnt do crap like this one.
It was pretty pathetic, I got stuck on flat ground ;D
Old November 29th, 2008, 12:48 PM   #43
Daniel
SFA Ranger
Daniel's Avatar
Originally Posted by 98-S10-lifted View Post
what PSI do ya think I should run with my tires so I dont get a bunch of wear in the middle and have the wear more even? I have 31x10.5R15 on 15x7 rims.
I run 30psi in mine.
Get a locker or limited slip, it will help alot.
Oh and M/T's suck on compact snow and ice.
Thus why I'm running some fugly ass A/T's.
Daniel is offline   Reply With Quote
Old November 29th, 2008, 02:34 PM   #44
DaBen
x2 on the LSD or Locker. Once I fixed my LSD I was 2wheelin' everywhere.
DaBen is offline   Reply With Quote
Old November 29th, 2008, 02:48 PM   #45
98-S10-lifted
my LSD wasnt working, so when I got stuck one side was completely covered in mud and the other kinda clean.
I am gonna do gears and lockers once I get a new 4x4 tail housing for the trans and throw the t-case that I have on. And hopefully somtime before summer I will be somewhere decent with the truck.
Thanks on the PSI, I ended up running at 30 PSI as well
My brother was locked and geared and I did better than him at the mounds on T-Day, as long as I was rolling I was decent.
Old December 4th, 2008, 04:09 PM   #46
98-S10-lifted
Well, I got a reason to work on the truck again. I just broke it going threw a small whole. I figured it was bound to happen, the leaf mount finally busted off. So I am close to tucking my tire :)
Checked out prices and junkyards for the parts for the swap. no luck on the trans and transfer case at most places, but found one combination w/55,000 miles on it for $950. I think I am gonna look for something cheaper. only saw two cherokees and teh D30's didnt look so great. I got two more big places where I know I will have more luck and I know I will be able to find everything so I am hoping to fall into some money soon.
Old December 23rd, 2008, 12:24 AM   #47
cj7on44's
cj7on44's's Avatar
my old ranger had that same shackle problem. when i was doing research on a sas with the d30 i found out they were using the Rubicon express long arm bars from a Cherokee or wrangler. that looked like a nice and clean set up.
cj7on44's is offline   Reply With Quote
Old December 23rd, 2008, 09:55 AM   #48
98-S10-lifted
well the truck is up and driving again.
I decided for the sas on the truck that I was doing leafs. probably using YJ leafs, start with stock to see how much lift I get and then If I need more then I will buy some lift ones.
I'm using a D30 to keep the cost down, so I only do one axle instead of having to do both front and rear.
Old December 31st, 2008, 06:02 PM   #49
98-S10-lifted
Well my project just got a jump start today. Thanks to "Fraser" I got a Decent D30. and once I got home, I headed to the junkyard to get the front leafs off of a YJ, My brother and I made a personal record for getting ceased up bolts out and getting the leafs out all in 50 minutes before the yard closed.
Now all I need is some square tubing to make the front crossmember and some more tubing for the hangers and shackles.
Old January 1st, 2009, 05:57 PM   #50
98-S10-lifted
put more work into the axle today, about 4hrs worth. It was horrible trying to cut off the shit for the xj 4 link. but it looks better and somewhat cleaner.
Old January 1st, 2009, 11:15 PM   #51
Fraser
Fraser's Avatar
that one mount was already halfway gone
Old January 1st, 2009, 11:41 PM   #52
98-S10-lifted
I think the rotton mount was on the easy side
It looked easier to cut off than it was, might have helped if I had good tools.
Old January 6th, 2009, 12:26 PM   #53
98-S10-lifted
possibly getting a parts explorer this week, its a first gen explorer. I am gonna use the trans, and front drive shaft for sure, and possibly using the rear drive shaft to extend the one for the ranger, and possibly use teh push-button transfercase.
Once I get it/if I get it, I am gonna use the parts I need and either part it out or use it for the next project, I am not sure yet.
Old January 6th, 2009, 12:34 PM   #54
cj7on44's
cj7on44's's Avatar
If That Has Buckets I Might Be Intristed In The Front Seats
Old January 11th, 2009, 06:26 PM   #55
98-S10-lifted
Well the explorer didnt work out, called and left a message, called back later and said someone was "looking at it". oh well, didnt need to waste money on that anyways.
well, got a little progress, I ordered a bunch of stuff from Ruffstuff. Looks like I have, and have stuff on the way to get the axle all the way in.
I got the
spring perches for the D30
6" long shackle pieces
The leaf spring hangers
and the shackle hanger with bushings
all ended up being $158 shipped at least I know all of the stuff is going to be the same and more accurate than I could make everything.
Old January 14th, 2009, 04:08 PM   #56
98-S10-lifted
Got the Parts
Shackle pieces:
Spring perch and Shackle hanger w/bushings:
Leaf spring hanger:
Spring perch again:
Sticker:
Old January 14th, 2009, 08:18 PM   #57
masterbeatty
masterbeatty's Avatar
nice. i like it alot. what gears are you guna run?
Old January 14th, 2009, 10:28 PM   #58
98-S10-lifted
not really sure yet, I wanna see how bad it is with 35"s on there before I decide. So either 4:10 or 4:56
Old January 17th, 2009, 01:10 AM   #59
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
those are some skinny perches you probably will break the stock yj leafs after awhile buddy of mine he kept breaking them can't wait to see it done
Bronco Ollie is offline   Reply With Quote
Old January 21st, 2009, 04:01 PM   #60
98-S10-lifted
no more ranger, traded it for a 92 F150 4x4. all the stuff I have for the sas stuff is going to my brother.
Page generated in 0.39048 seconds with 83 queries
