no more ranger, got traded - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2008, 01:25 AM   #21
Daniel
SFA Ranger
Daniel's Avatar
Nice, reminds me of my truck.
I posted pictures of my SAS if you are interested or have any questions feel free to pm me.
I see you don't live very far, my dads shop is on Wayne road just south of ford (speedy muffler), if you need any help hes a member on here (04 EDGE).
Daniel is offline   Reply With Quote
Old October 30th, 2008, 10:07 AM   #22
98-S10-lifted
98-S10-lifted's Avatar
cool thanks, but it will be a year at least before I try to start a sas, dont want to waste 700 bux on nothing
98-S10-lifted is offline   Reply With Quote
Old November 4th, 2008, 10:28 AM   #23
98-S10-lifted
My pitman arm doesnt want to come off and I broke a second pitman arm puller. Does any know anything that I could do to get the pitman arm off? besides a BFH cause I tried that too.
would I be fine without a drop pitman arm?
Old November 4th, 2008, 10:34 AM   #24
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
two hammers, Smack them together on either side of the pitman arm. Worst case, grab a die grinder.
ckupq is offline   Reply With Quote
Old November 4th, 2008, 10:37 AM   #25
1fstfox
No 4X4. :-(
1fstfox's Avatar
If the nut is off then try heat like I said before. Warming up the pitman arm will make it expand and *SHOULD* almost fall off the steering box. That or an air hammer if you have access to one.
HEAT and VIBRATION are your 2 best friends when working on something that don't want to break free.
1fstfox is offline   Reply With Quote
Old November 4th, 2008, 10:38 AM   #26
98-S10-lifted
That was quick
I will try that, I was gonna leave that cutting as a last resort plus I have to buy cutting wheels cause all I have are grinding wheels.
Thanks!
Old November 4th, 2008, 11:21 AM   #27
86scottsdalek10
86scottsdalek10's Avatar
im not really sure i understand why you need a drop pitman....i have a 97 ranger 2wd and i am going coilovers and 4.5" wider ibeams/custom radius arms and 16-20" of travel and all that is required is to have stock steering extenders...no drop pitman is needed....by the way i have a 4" on it right now and 33's with fiberglass fenders and no pitman arm and it works just fine and does not need it. just my .02
86scottsdalek10 is offline   Reply With Quote
Old November 4th, 2008, 11:29 AM   #28
98-S10-lifted
Did/do you have any problems with the tie rod ends or any pre mature wear on anything without doing the drop arm. I figured if I got the drop arm I would put it on if I could get the old one off. Thanks.
Old November 4th, 2008, 11:50 PM   #29
Mclovin
"The Situation"
Mclovin's Avatar
the little propane torch will prob do the trick it will just take forever ! try letting some PB blaster sit on there for a bit..
Old November 5th, 2008, 02:45 PM   #30
bj house
bj house's Avatar
Either that or pick up a MAPP gas cylinder that will work with the propane tip and get many times hotter.
Old November 6th, 2008, 09:47 PM   #31
98-S10-lifted
Update, I got the pitman arm off, I rented another puller (third one being used) and used a bunch of PB blaster and wd-40, a BFH, and then hit the top-ish of the pitman arm about 20 times and the pitman arm came off. Then I got the drop pitman arm on, next thing to do is the brake line and then get all new drag link cause its all sloppy. Then maybe, just mayb I will be able to drive it for a while.
Thanks to all for the help!
Old November 6th, 2008, 09:57 PM   #32
masterbeatty
masterbeatty's Avatar
wana buy a 77 f150 currently front wheel drive haha im so tired of breakn stuff
Old November 6th, 2008, 10:15 PM   #33
98-S10-lifted
no money til I get to drivin the too-weel and sell the expli
Old November 6th, 2008, 10:27 PM   #34
ddeadserious
ddeadserious's Avatar
Nice looking Ranger, saw it in the driveway the other day.
Nice work.
ddeadserious is offline   Reply With Quote
Old November 6th, 2008, 10:40 PM   #35
98-S10-lifted
Thanks, cant wait to see what it drives like, I drove it a couple of times then the brakes blew and not able to drive it til I get that fixed.
I got a rim for the spare now I just got to get it on the rim, should be fun stuff trying to get it on another thing I might do is, put another leaf in so the ass dont sag when I put my old cap on, either that or find a roll bar like I had in my first ranger.
Now I just have to find old pics of the ranger to be able to find that roll bar lol.
Old November 11th, 2008, 12:25 PM   #36
98-S10-lifted
what PSI do ya think I should run with my tires so I dont get a bunch of wear in the middle and have the wear more even? I have 31x10.5R15 on 15x7 rims.
Old November 12th, 2008, 07:36 PM   #37
98-S10-lifted
front end all done and purdy, well the steering part anyways. I got all the stuff I need to do the brakes tomorrow and then I think I should be done with it for a while. util I get more money for other things of course
Old November 18th, 2008, 07:28 PM   #38
98-S10-lifted
Update... I got the brake line fixed and had to bleed the brakes and when I thought I was done, I was far from it. When I tried to bleed the brakes the bleed screw broke off, when I tried to get the drum off it cracked and broke
So now I have a new list of theings to do and unfortunately teh truck wont make it to mounds on T-Day
I have:
1 brake cylinder to do
replace a spring the broke off the drum brakes
put new drum on
bleed the brakes
and newly discovered, I have to do the front part of the leaf spring hangers now
check out why my truck doesnt want to shift gears occasionally
and alignment
so far I spent more money than I thought I would.
Old November 18th, 2008, 08:46 PM   #39
DaBen
Save youself another headache and do both drums with both wheel cyl. and new shoes and hardware kits for both. You know that when you are reassbling it something else is gonna break. That is the way it always happens to me anyway.
DaBen is offline   Reply With Quote
Old November 21st, 2008, 05:53 PM   #40
98-S10-lifted
Got the brakes mostly done, but I have to do the brake lines on the axle because those leak too. So tomorrow I am doing the brake lines on the axle, bleed the brakes and tada its driveable.
I got the leaf hangers and once I get the truck aligned tomorrow, I am going to head out to the junkyard to get a stock ranger leaf block or an extra stock leaf from another truck because the back is too low after it has been sitting for a while.
But for sure I will be driving the truck tomorrow.
Page generated in 0.45894 seconds with 83 queries
