*SOLD* 2004 Gmc K2500hd - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2008, 09:04 AM   #1
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
Default *SOLD* 2004 Gmc K2500hd
2004 GMC K2500 HD 4x4 extended cab short bed.
LQ4 6.0L coupled to 4L80E
4.10 gears with gov-lock in the rear (14B FF)
Towing package with trans temp gauge. I've never had it climb above 170-ish and that was on a huuuuuuge hill out east.
125K miles as of recently
Just had the exhaust manifolds replaced (stock ones leaked due to bolt heads popping off, common problem out of the box with these engines. The aluminum heads and iron manifolds expand/contract at different rates and the factory manifold bolts could not take it, and the heads would shear off then the manifolds would leak at the head. The new bolts are able to take the load though, so that should not be a problem anymore)
Body is in good, but not great, condition.
Scratches and minor dents here and there, and the rear bumper is bent (Previous owner backed it in to something) and dented the rear 1/4 panel. No rust though. Only rust on the truck would be underneath where most of the components (axles, suspension, etc) have the typical rust belt surface rust.
Interior is in good condition with one split seam on the passenger side front seats head rest
Runs excellent, drives excellent.
I figure the value of the truck is $10k or so so we'll start there.
edit: the brake pedal has the rubber back on it. I got a new pedal cover.
I can try to get new pictures upon request, but I don't have a camera anymore so it might take some time.
xj_man_646 is offline
Old October 22nd, 2008, 10:21 AM   #2
xj_man_646
Wheeler-less
xj_man_646's Avatar
Bump?!?
Old October 24th, 2008, 12:47 PM   #3
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump. would also consider trading for older diesel.
Old October 28th, 2008, 06:00 PM   #4
sam
sam's Avatar
trade for 02 avalanche?
sam is offline
Old October 28th, 2008, 06:30 PM   #5
xj_man_646
Wheeler-less
xj_man_646's Avatar
If its the one in your av, no thanks. If it were a newer avalanche in which they got rid of all that plastic and made them one color I'd probably consider it. Sorry.
Old October 28th, 2008, 06:45 PM   #6
montecarlo0992000
i got a 01 gmc half ton with a spray in bed liner around 120000 milles same collor call if interested 989 225 0566
montecarlo0992000 is offline
Old October 28th, 2008, 06:58 PM   #7
gmotox
gmotox's Avatar
pm sent on 2001 Dodge Cummins quad cab 4x4
gmotox is offline
Old October 28th, 2008, 08:25 PM   #8
xj_man_646
Wheeler-less
xj_man_646's Avatar
can you email me any pictures?
Old October 28th, 2008, 10:38 PM   #9
94transam25th
94transam25th's Avatar
you have pm
94transam25th is offline
Old November 2nd, 2008, 07:28 AM   #10
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old February 19th, 2009, 08:05 AM   #11
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old February 20th, 2009, 11:24 AM   #12
xj_man_646
Wheeler-less
xj_man_646's Avatar
top
Old February 21st, 2009, 07:54 AM   #13
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old February 23rd, 2009, 01:15 PM   #14
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old February 27th, 2009, 08:19 AM   #15
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old March 9th, 2009, 10:41 PM   #16
Countrygirlkt
trade?
01' jeep wrangler sport 72,000 miles NO RUST
Countrygirlkt is offline
Old March 10th, 2009, 06:51 AM   #17
xj_man_646
Wheeler-less
xj_man_646's Avatar
Originally Posted by Countrygirlkt View Post
trade?
Sorry, I need some sort of tow rig.
Old May 30th, 2009, 07:55 AM   #18
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Old May 30th, 2009, 07:56 AM   #19
xj_man_646
Wheeler-less
xj_man_646's Avatar
Keep in mind the pics are somewhat old now. The carpet has been cleaned up a lot since these were taken, and it has nice floor mats.
Old May 31st, 2009, 09:10 AM   #20
xj_man_646
Wheeler-less
xj_man_646's Avatar
bump
Page generated in 0.38334 seconds with 84 queries
