setting pinion angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2008, 09:30 AM   #1
howell_jeep
Last Free Man
howell_jeep's Avatar
Default setting pinion angle
I put a 4" suspension lift (springs) on my cj7 and I need to weld in new spring perches (pads) onto the axle. Does anyone have a link to an article on how to do this?
Do I need to have the body on to do this, or is the frame and drivetrain all that's needed?
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old October 20th, 2008, 10:28 AM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Your jeep has a D300? Are you using a CV shaft or just single cardian shaft?
For CV, you want to point the pinion right at the output on the tcase (We usually go about 1-2* below that)
For Single Cardian shaft, you need to set the pinion to the same angle the output is on the tcase. You can do that with an angle finder.
JcrOffroad.com
Like us on Faceook!
Old October 20th, 2008, 10:57 AM   #3
95geo
newbie
95geo's Avatar
within 3 degrees of paralell is usually acceptable and you wont feel any vibrations, if it is a front I would pay more attention tot he caster angle than the pinion angle.
you should have the springs compressed to a location close to ride height so you dont have to redo something if it isnt right later on.
Old October 20th, 2008, 10:58 AM   #4
howell_jeep
Last Free Man
Yes, it has the d300 in it and I want to use a cv driveshaft. I have not lowered the t-case. So I would just point the axle pinion at the transfer case pinion (or 1-2* lower) and weld the perches?
Also, do i need to do anything to the front setup? I have just left it the way it was before the lift?
I SHOOT RAW!
Old October 20th, 2008, 11:01 AM   #5
howell_jeep
Last Free Man
"within 3 degrees of parallel" is that true even for cv driveshaft?
and i was just thinking about the rear axle at this point, I'm putting a fiberglass body on it, so there will not be much more weight added over the rear axle.
do I also have to redo the perches on the front axle? i was under the impression that i only needed to do the rear
I SHOOT RAW!
Old October 20th, 2008, 11:08 AM   #6
Bones
Bones's Avatar
I would sugest adding the tub onto the frame, as well as any other normal vehicle weight (top, seats, fuel tank, etc)
You're springs will flex with the weight of the crap mentioned above, which will affect your pinion angle.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 20th, 2008, 12:02 PM   #7
95geo
newbie
95geo's Avatar
I have no idea if you will see problems or not but typically if 2 u-joints are within 3 degrees of one another you will not notice any vibrations.
Old October 31st, 2008, 12:37 PM   #8
superduty
superduty's Avatar
this might help.
http://www.pirate4x4.com/tech/billav...ft/index2.html
superduty is offline   Reply With Quote
Old October 31st, 2008, 12:42 PM   #9
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
cv d shaft
point the pinion 1-2 degrees below the t case output
Old October 31st, 2008, 12:56 PM   #10
95geo
newbie
95geo's Avatar
Originally Posted by hosejockey4506 View Post
cv d shaft
within 3 degrees of pointing directly at the output
Old October 31st, 2008, 03:08 PM   #11
hosejockey4506
Visiting Admin
i see what you mean
but when i first read your post and the preceeding ones it sounded like you were saying make the pinion with in 3 degrees of the output of the t case
Page generated in 0.30209 seconds with 56 queries
