Ever Broken a ford 7.5? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2008, 10:11 PM   #1
Jdc215
Jdc215's Avatar
Default Ever Broken a ford 7.5?
I hear of people swapping the explorer 8.8 into rangers and bronco II s frequently. they all talk about how much stronger they are than the 7.5 but i honestly have never heard of a 7.5 breaking. I dont plan on running anything bigger than 33s on it but if you have ever broken a 7.5, how did you do it? do you think it is at all likely running 33s?
Jdc215 is offline   Reply With Quote
Old October 19th, 2008, 10:32 PM   #2
88mudder
In the band!
you will be fine with the 7.5 on 33's. The front axle is of most concern.
Old October 19th, 2008, 11:15 PM   #3
Jdc215
Jdc215's Avatar
i think it would do fine, but i would like to get a better idea of what its limits are.
Old October 20th, 2008, 12:25 AM   #4
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
33's will be fine on the dana 35 front and the 7.5 rear i have never heard of anyone breaking a 7.5 either
Bronco Ollie is offline   Reply With Quote
Old October 20th, 2008, 06:58 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
I broke mine doing a hole shot with my 4 banger ranger rollin on some massive 185s.
Old October 20th, 2008, 07:22 AM   #6
i watched one break right after this happened
Old October 20th, 2008, 10:16 AM   #7
Jdc215
Jdc215's Avatar
WOW. i wouldnt doubt it. How far off the ground is that?
Old October 20th, 2008, 12:41 PM   #8
frdboy
frdboy's Avatar
I broke one in a mustang with a mild 302, twisted the ring gear and sheared the bolts off.
I didn't even know it untill I smelled gear lube one day looked uderneath and seen two holes in the cover from bolt heads breaking off and getting between the gear and cover.
Pull the cover and it had only a few bolts left.
Old October 20th, 2008, 12:48 PM   #9
silveranger93
silveranger93's Avatar
I ripped the spider gears out of one. Dropped the clutch at about 2500 rpm in 4 low with the hubs unlocked. Truck didn't even move, just tore the spiders apart. Last time I tried burnouts on pavement.
4L V6, 35s, Hays clutch
silveranger93 is offline   Reply With Quote
Old October 20th, 2008, 01:20 PM   #10
fsumotorhead
N8KVB
exactly what broke on mine, only mine was a 2wd.
Old October 20th, 2008, 02:21 PM   #11
ibleedblue1385
"god damn cam"
ibleedblue1385's Avatar
Just dont put v8 power in front of it, they dont last long then thats for sure.
ibleedblue1385 is offline   Reply With Quote
Old October 20th, 2008, 08:56 PM   #12
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
my opinion, swap it for a 8.8.
the 7.5 will leave you stranded and mad!
trust me!
Old October 20th, 2008, 10:46 PM   #13
Jdc215
Jdc215's Avatar
i dont have money for an 8.8 right now. i am just trying to get a better feel for when i should get a 8.8. and what i can do with my 7.5.
Old October 20th, 2008, 11:18 PM   #14
Bronco Ollie
you can leave the 7.5 in for now just when you have the money change it
Old October 21st, 2008, 09:22 AM   #15
04 EDGE
04 EDGE's Avatar
i wouldn't spend ANY money on the 7.5
Old October 21st, 2008, 11:31 AM   #16
Jdc215
Jdc215's Avatar
i might put some clutch pads in the l/s unit but that would be it.
thanks Ollie thats what i was thinking.
i think ive got a good idea of how much the axle can take, which is more than i plan on putting it through.
Page generated in 1.63261 seconds with 71 queries
