flex plate double check? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2008, 02:15 PM   #1
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Default flex plate double check?
I just want to make sure a 76 302 c4 flex plate is 28.2 oz imbalance and can be used on a 95 351w? Pretty sure but don't want to f' it up
Old October 19th, 2008, 07:28 PM   #2
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
i want to say no it will not work, the newer engines used the higher weight, 56 ounces i think. you can get flywheels now that are the smaller tooth count in different weights.
who did something stupid like this?
Old October 19th, 2008, 08:42 PM   #3
Jeepaholic
Jeepaholic's Avatar
My research found that only the 302/5.0 went to the 50 oz around the early 80's. And the 351 stayed with the 28.2 imbalance. But wanted to double check.
I had the original 351 flex plate but the torque converter bolt pattern was different than the e40d pattern. they are the same tooth count also.
It is in now but it will be awhile before it is ran.
Old November 8th, 2008, 10:20 PM   #4
DeRanged mudder
completly insane
DeRanged mudder's Avatar
Send a message via Yahoo to DeRanged mudder
Only the H.O.s had the 50oz in the '80s. I'm not sure when or if they changed them all. I do know that I have had trouble finding the right balance flywheel for a Windsor before.
DeRanged mudder is offline   Reply With Quote
Old November 21st, 2008, 11:23 AM   #5
BOGDOG
BOGDOG's Avatar
They never changed the balance weight on 351W's just the 302/5.0
Page generated in 0.19347 seconds with 38 queries
