HP Ford D44 Narrow, explorer 31 spline 8.8 to match - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2008, 03:37 PM   #1
Default HP Ford D44 Narrow, explorer 31 spline 8.8 to match
Front Axle
1977 F150 High Pinion D44 6"s shaved from pass side to match EB axle shaft length
Wedges removed and currently has leaf spring perches welded on (not the cast on wedges)
4.88 Gears ($150)
Using the full time lock-outs (not selectable)
Yukon Chrome moly axleshaft on the right side with a 5-760x ujoint ($165), drivers side stock, stubs are Ford not chevy
1975 chevy flat top knuckles...Pass milled, drilled, studed for hi steer, chevy calipers, caliper bracket
(related parts over $200)
Koz Hi-Steer Arms for chevy 1 ton tie rods ($130) (Tie Rods not included)
Ford Rotor/hub 5x5.5 lug pattern ($50)
Ball Joints are tight and good, i have the rotors/hubs off right now getting a good bearing repack and resurface on the rotors. Might need new axle seals, i think their might have been one seeping a very small amount of fluid.
Rear Axle
31 Spline Explorer 8.8 ($100)
Spiders welded to carrier (was open carrier, been running this for over 4 years on/off pavement)
4.88s ($125)
Disc Brakes ($100) no parking brake set-up on the axle currently, brake hoses in fair
condition and included
Axle Tubes welded to diff housing
Solid Diff Cover ($110)
1.25" lug adapters going from 5x4.5 to 5x5.5.....matches width of front axle ($100)
Spring perches and shock mounts currently set-up for a SOA on the rear of an Explorer
Located in Middleville, still under truck
Pair $700 or i will install a good set of stock knuckles and brakes and then the pair would be $600 and i'll keep the hi-steer components
Perfect for a YJ-Drivers Drop and hi-steer done.
discs on rear with lug adapters
diff cover
Hi- steer
Axle shaft
veiw of drivers side knuckle
Basically after i reassemble the hubs/rotors this will be ready to rock. Just install your brackets and bolt it in.
CheapThrillB2 is offline
Old October 16th, 2008, 07:55 AM   #2
Bump for YJ guys!
feva4u is offline
Old October 16th, 2008, 01:01 PM   #3
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
you cleaned your shop !!
two_much_talk is offline
Old October 17th, 2008, 10:46 AM   #4
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Good Deal for the price.
KennyOffroad is offline
Old October 20th, 2008, 08:38 AM   #5
ttt
Old October 22nd, 2008, 04:21 PM   #6
KennyOffroad
Still 4 Sale ?
Old October 22nd, 2008, 04:23 PM   #7
badazzamc
Get Some
badazzamc's Avatar
would you sell just the front? how much
badazzamc is offline
Old October 22nd, 2008, 05:12 PM   #8
Old October 22nd, 2008, 07:31 PM   #9
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
what is the width of the front (wms) and how does it compare to the rear with he adapters on
mean_greenEXJAY is offline
Old October 22nd, 2008, 07:33 PM   #10
the width in the rear is almost exact of the front, i'll have to get the WMS to WMS tomorrow
Old October 22nd, 2008, 07:41 PM   #11
near as i can tell the front is around 61"s and the rear is 62"s APPROX.
Old October 23rd, 2008, 03:04 PM   #12
ttt
Old October 26th, 2008, 05:27 PM   #13
top
Old October 27th, 2008, 01:52 PM   #14
top
Old October 27th, 2008, 02:29 PM   #15
Pre4runner
Bike Dude
Pre4runner's Avatar
So yea if my junk sells i might buy your junk.
Pre4runner is offline
Old October 27th, 2008, 03:15 PM   #16
let me know, i cut you deal
Old October 28th, 2008, 09:57 AM   #17
insane88yj
insane88yj's Avatar
nice lookin axils wish i had the cash are you goin bigger or scraping project
insane88yj is offline
Old October 28th, 2008, 03:37 PM   #18
bigger & FW
Old February 12th, 2009, 09:15 PM   #19
bigbchevy
missmrgreenagain
bigbchevy's Avatar
pm me if you still have them
bigbchevy is offline
Old February 12th, 2009, 09:20 PM   #20
MiNi Beast
MiNi Beast's Avatar
$1150.00
Sweet then I'll take the rear for $50
MiNi Beast is offline
Page generated in 0.39777 seconds with 83 queries
