solid axle swap on my S10 blazer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2008, 09:40 AM   #1
Chevkid09
HILLBILLY
Default solid axle swap on my S10 blazer
I would like to convert my Blazer from IFS to a solid axle. if any one here has done it I would like to know exactly what is involved and how costly the whole project will be.
Chevkid09 is offline   Reply With Quote
Old October 15th, 2008, 02:53 PM   #2
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
If it is done right, it costs quite a bit.
I half assed some stuff on mine and I am still not done yet. I think I have somewhere near $750ish into mine.
I ended up cutting out my whole front end with a torch and scrapping it. Made a new front crossmember, cut out old one, I have to modify my Y-pipe to make room for a front driveshaft, brackets for arms, panhard bar, shorten steering link, shorten panhard bar, steering box from an Astro, turn rear springs around, replace all the rear leaf bushings, make front coil buckets, make shock mounts, make shackles, brakework, make my new driveshafts and take them somewhere to get them balanced. I know I am missing a few things for sure.
It takes a lot man, there are endless ways to do something like that too.
Search around. There is a lot of stuff in this site about that stuff. Check out www.zr2usa.com and www.s10forum.com also. Lots of info, just need to search.
I did research for almost a year before I started mine, and now I don't even know if I did enough.
Something I forgot to add...
It is easier for people to help you if you know what you want out of your vehicle once the project is done. Like if you want a low center of gravity, or jacked way the hell in the air, tire size, for mud, rocks, dunes, whatever.
Grunto is offline   Reply With Quote
Old October 15th, 2008, 07:12 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
http://www.3leaffab.com/ just order one of these guys kits. you didn't say if you had a 94 and down or 95 and up blazer. 94 and down you can use there kit. just supply axle, springs and steering components
Old October 15th, 2008, 07:20 PM   #4
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
CAGE off road makes a bolt in sas kit to put a ford axle in the front with radius arms and coils. Not sure what years they make it for tho.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old November 22nd, 2008, 04:56 PM   #5
Grizzy
Griztek Off Road
Grizzy's Avatar
I know this is a bit late for this thread, but here is a link to my straight axle swap I did on my 96 Jimmy.
http://www.griztekusa.com/JimmyProject.html
Feel free to ask any questions. If you have fab skills, grinder , sawzall, welder, and maybe a chop saw you can do this all for less than $1000. I still own this truck 5 years later and have had no problems. To this date I have put on over 60K miles on it since the swap. Dont' let anyone tell you it must be a hack job either. Many people have been very impressed with the complete package and are amazed it looks and functions like it does and I didn't spend an arm and a leg to do it.
Grizzy is offline   Reply With Quote
Old November 22nd, 2008, 07:46 PM   #6
Grunto
Grunto's Avatar
Grizzy what kind of springs are you running in the front?
Old November 27th, 2008, 02:02 AM   #7
Grizzy
Griztek Off Road
Grizzy's Avatar
I used one of my gazillion pairs of left over XJ springs. They are a perfect fit and free. Grunto, what's it you have?
Old December 8th, 2008, 02:49 AM   #8
keithhammondhonda
beer+4x4=woohoo!!
keithhammondhonda's Avatar
old fords 78 79 so on came with coil spring and trailing arms, if you can find a set of 44 hp and 9" on the truck, you can cut off all the buckets and brackets and wield them on the s-10 quick and ez, i sold three sets of them this year and every one had great results. the one is a s-10 running around tc right now the guy uses it for a dd (black newer style and squats in the rear a bit look REAL GOOD pre runner style)
keithhammondhonda is offline   Reply With Quote
Old February 2nd, 2009, 04:23 PM   #9
DIRTY DIGGER
DIRTY DIGGER's Avatar
i am wanting to use leaf springs in my conversion is there anyone out there with input on this
DIRTY DIGGER is offline   Reply With Quote
Old February 2nd, 2009, 04:25 PM   #10
DIRTY DIGGER
it being used as a mud truck and not a trail truck so it needs to have leafs front and rear to fit into the rules and regulations for the class i will be competitive in
Old February 2nd, 2009, 04:36 PM   #11
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
www.sky-manufacturing.com has a leaf spring SAS kit. I've heard a lot of good stuff and I'll be using their kit sometime soon.
Old February 2nd, 2009, 09:37 PM   #12
DIRTY DIGGER
thank u for the website and info i had already started fabing my own kit and it is alot of work i was kinda shittin bricks
Old February 3rd, 2009, 01:55 PM   #13
DIRTY DIGGER
has anyone used the leaf spring kit? what sized tires and lift do u have? i have a 99 s-10 and am wanting to run 40" boggers on rear and 38" boggers on the front and am not wanting to cut out alot of fender i am curious if anyone has any kind of idea on the size of lift i might need
Old February 3rd, 2009, 02:05 PM   #14
dragtruk
Questionable..
dragtruk's Avatar
Send a message via AIM to dragtruk
all your answers will be here ive been researching this for a while and this is the best place, http://www.s10forum.com/forum/4wd-sfa/
project s-ton is a good for pics,
and the 87 SAS project is really good because he uses the sky front kit.
dragtruk is offline   Reply With Quote
Old January 11th, 2012, 09:09 PM   #15
knaffie
knaffie's Avatar
For anybody searching old threads, 3 leaf fab flopped.
Synergy still sells coil and leaf spring SFA swap kits for 82-93 and 94-04 S10.
http://www.shop.synergyoffroad.com/8...?categoryId=-1
http://www.shop.synergyoffroad.com/9...?categoryId=-1
Old September 22nd, 2012, 10:36 PM   #16
tooshay
Default how can I figure out what gears my s10.blazer has
How can I find out what gearing I have on my 1989 s10 Chevy blazer 4x4 looked on both diffs and I didn't find any tags on them the reason I ask is I wanna get a Dana straight axle off a Jeep just wanna make sure they match gears with the rear diff
tooshay is offline   Reply With Quote
Old September 23rd, 2012, 06:09 AM   #17
knaffie
knaffie's Avatar
call the dealer with the VIN#
or pull the cover and count the teeth
or count driveshaft versus tire rotations
Old September 25th, 2012, 09:24 PM   #18
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Or look up your rpo codes gu6 are 342, gt4 373's gt5 410's and such as that. There the 3 letter/number combo's in your glove box
beaterk5 is offline   Reply With Quote
Old September 25th, 2012, 10:42 PM   #19
bdd1469
bdd
bdd1469's Avatar
Bet ya a beer it's 3:42 which you wont find in a jeep.If you get lucky it will be 3:73 a common jeep gear also. It could also be 3:23,or 4:10 if it was ordered.
Fyi get a 8.5 ten bolt for the rear out of a zr2 .They have disc brakes,posi,and are much stronger then your 7.5.They bolt in,and most have 3:73. I see them at lkq all the time for less then $200.
Old September 26th, 2012, 06:49 AM   #20
knaffie
knaffie's Avatar
The G80 in the ZR2s is garbage. If you get one, you should throw it out and replace it with something better.
Page generated in 0.47646 seconds with 83 queries
