1998 blazer 4x4 problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2008, 10:59 PM   #1
cantafiof
drive hard and fast
Send a message via MSN to cantafiof
Default 1998 blazer 4x4 problem
my 4 wheel high light keeps coming on but it is still in 2 high some times it just switches what should i look at to try to find the problem
cantafiof is offline   Reply With Quote
Old October 15th, 2008, 05:47 AM   #2
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
The 4w computer for that should be behind the passenger kick panel. Ive seen corrosion on one before due to the sunroof drain that runs down the A pillar. Its probably worth pulling and inspecting.
blizazer is offline   Reply With Quote
Old October 19th, 2008, 02:54 PM   #3
cantafiof
drive hard and fast
ok ill take a look right now it is stuck saying it is in 4 wd high but it is 2 high
Old October 19th, 2008, 03:12 PM   #4
cantafiof
drive hard and fast
took a look its not that box i got all power there and its all working good there... is there any other place to look
Old October 19th, 2008, 03:31 PM   #5
beedle4
beedle4's Avatar
is the reansfer case engageing but not the front axle slip coller? If so check out the transfer case vaccum switch. They have alot of issues and are known to leak. There is a updated version. Do your heat selecter vents work on all positions? Or are they stuck on one setting?
Old October 19th, 2008, 04:42 PM   #6
cantafiof
drive hard and fast
i will take a look at it thanks the heat works but it takes a while to switch from setting to setting
Page generated in 0.24161 seconds with 41 queries
