Lock right Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2006, 10:17 PM   #1
nobodycares
Beotch
nobodycares's Avatar
Default Lock right Help
I have a Lock right in my ZJ that was working but before I went out wheeling the rear would only drive on the left side only. Has anyone else had this problem, and what should I look for when I tear in down? Are the teeth worn down, do I need to replace the springs..... any help would be appreciated.
Thanks
nobodycares is offline   Reply With Quote
Old May 3rd, 2006, 10:27 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I would check what you have mentioned. Then I would check the gap between the driven gear and the croos pin. This will tell you if the case is worn.
Old May 4th, 2006, 12:26 AM   #3
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Silly but busted axle?
Old May 4th, 2006, 07:27 AM   #4
Yep. Check the teeth, check the 4 pins to make sure they didn't break(you can buy new ones for a few dollars..), and using feeler gauges, check the gap between the two halves of the lock rite.
You can go to richmond gear's website and download a new manual if you need to, to get the spec for the allowable gap between the halves.
Old May 4th, 2006, 10:29 AM   #5
nobodycares
Beotch
Thanks for the info, I will be checking it out tonight.
The axle is ok. my guess is its worn.
Thanks again
Old May 4th, 2006, 08:48 PM   #6
nobodycares
Beotch
Looks like the inner spacer that locks into the outer couplers sheered of a tooth and it got wedged and would not let the coupler engage with the inner part.
Page generated in 0.16237 seconds with 41 queries
