F250 5.4 liter hesitation and chugging - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2008, 09:25 AM   #1
Immortal
NO RELIGION WAT!
Immortal's Avatar
Exclamation F250 5.4 liter hesitation and chugging
Seems to happen randomly at take off and while cruising on the freeway. Almost seems as if it is misfiring. No codes. I dunno. I am new to the ford stuff. I am about ready to drop off at a stealership to have them diagnose it. Halp
Old October 13th, 2008, 09:31 AM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Does it almost feel like the trans is slipping? You give it gas, it revs up but won't accelerate?
Is it idling rough or starting to run rough while driving?
Old October 13th, 2008, 09:37 AM   #3
Immortal
NO RELIGION WAT!
Immortal's Avatar
gawd I hope not, but my dodge did what you described and it was pretty obvious. The f250 doesn't seem that way. Idle is fine at start up and acceleration. It gits up and goes on the freeway for a f250. However it literally hesitates and chugs randomly, but at least once per day of driving it.
Old October 13th, 2008, 09:40 AM   #4
Bones
Bones's Avatar
there might be codes, even without a Check engine light... I woudl try an autozone or the like, and have them try to pull codes.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 13th, 2008, 09:41 AM   #5
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
pm swi dog on here, his 5.4 is doing exactly the same thing....I think he said it was leaking coolant into one of the holes where the spark plug is and is causing that one cylinder to misfire/short out every once in a while.
gotsand? is offline   Reply With Quote
Old October 13th, 2008, 09:41 AM   #6
GreaseMonkey
Pew pew!
When it chugs, if you give it more throttle, nothing happens?
I'm thinking TPS, but it could also be misfiring which can set inactive codes which won't set a light. Until the PCM sees it almost all the time or it happens enough, it won't set the check engine light on.
Old October 13th, 2008, 10:06 AM   #7
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
bad coil(s)
now all you have to do is find out what one it is.
i keep a bunch of spares for testing purposes.
Old October 13th, 2008, 10:13 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
When I give it more throttle it kind of sputters then clears up. When I keep the throttle on it kind of goes away once I go back to a cruise speed. Eventually it stays gone till it happens again laterish.
Old October 13th, 2008, 10:15 AM   #9
GreaseMonkey
Pew pew!
Probably not a TPS then. Intermittent misfire. 04 EDGE and what gotsand? said are definite possibilities.
I would pull all of the plugs and see what all of them look like and compare to each other like girls in the locker room.
Old October 13th, 2008, 10:27 AM   #10
Immortal
NO RELIGION WAT!
Immortal's Avatar
I just found this forum of issues about the coil packs......interesting no?
http://www.f150online.com/forums/eng...coil-pack.html
Old October 13th, 2008, 10:34 AM   #11
GreaseMonkey
Pew pew!
Could be that as well like Bones said. If you want to self diagnose, make sure all your spark plugs are in good shape and aren't white or have any deposits indicating a coolant leak like 04 EDGE said. If those look ok, get Autozone to pull up codes and see if their are any inactive misfire codes for specific cylinders. Swap a coil pack if you can and get it to do it again, go to Autozone and see if it switches to that cylinder, and then you've found the problem.
Or just take it to the dealer....
Old October 13th, 2008, 10:38 AM   #12
Immortal
NO RELIGION WAT!
Immortal's Avatar
If I can't fix I will have no choice, but to take it to a dealer. Wife will be primarily driving the f250 this winter so I want to eliminate any hiccups.
Thanks for all the help guys.
Old October 13th, 2008, 10:39 AM   #13
GreaseMonkey
Pew pew!
Are the coils and plugs in that thing a bitch to get to like the half tons?
On second thought, stop at Autozone and have them pull the code.
Check the plug for that cylinder, and if it's ok, it's probably the coil if you have a misfire code.
Remember that Ford has some asinine way numbering cylinders that is different from Dodge and Chevy.
Old October 13th, 2008, 11:45 AM   #14
fsumotorhead
N8KVB
fsumotorhead's Avatar
Check your spark plugs to make sure they aren't backing out of the heads.
Ford has a kit to fix this if it is the issue.
Old October 13th, 2008, 12:50 PM   #15
Immortal
NO RELIGION WAT!
Immortal's Avatar
hmmmmm I took a quick look at lunch and couldn't seem to locate the coil pack let alone the spark plugs
Old October 13th, 2008, 01:00 PM   #16
GreaseMonkey
Pew pew!
Isn't there plastic covers over the heads?
What year is your F-250, like an 04 right?
Old October 13th, 2008, 01:08 PM   #17
hollyhellrazor
you gotta be careful with the plugs on the 5.4 cause theyll pop out if they back out too far its about a 500 dollar to rethread a mechanic where i work has already rethreaded some of the plug holes on the v-10s there but he told me that when you pull the plugs if they start to give u any trouble coming out to turn them back in a little bit then loosen them again he says as long as hes been doing that hes never had any problems
hollyhellrazor is offline   Reply With Quote
Old October 13th, 2008, 01:17 PM   #18
Immortal
NO RELIGION WAT!
Immortal's Avatar
yes 04...no covers that I am aware of. I google a pic and I couldn't find one that looks like my motor
Old October 13th, 2008, 01:27 PM   #19
GreaseMonkey
Pew pew!
I'm having trouble finding pictures too....
Old October 13th, 2008, 01:28 PM   #20
GreaseMonkey
Pew pew!
Enter your DL# and look up under engine electrical. The procedure is there.
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
Page generated in 0.33804 seconds with 83 queries
