8.8 Yoke Flange bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2008, 08:18 PM   #1
Fraser
Fraser's Avatar
Default 8.8 Yoke Flange bolts
I have the size/ thread pitch one them, but I have been informed that they are a 12-point head. do they have to be the 12 point head? or are they specially hardened? [not at hardware store kinda bolt?]
Old October 12th, 2008, 08:23 PM   #2
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
i would think you could use any bolt in there as long as they are the same thread and stuff
Bronco Ollie is offline   Reply With Quote
Old October 12th, 2008, 08:26 PM   #3
jeepxj_boy_21
linked
jeepxj_boy_21's Avatar
they are still in my truck forgot to give them to you
jeepxj_boy_21 is offline   Reply With Quote
Old October 12th, 2008, 08:30 PM   #4
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
So long as they are grade 10.9 you should be fine.
Old October 12th, 2008, 08:32 PM   #5
using a std bolt in that thread size uses a much larger hex head, makes it very difficult to loosen tighten. The hex is larger enough that a socket will not fit do to clearance of the flange so only an open end wrench can be used.
Old October 12th, 2008, 08:33 PM   #6
Fraser
Fraser's Avatar
your slackin
Old October 12th, 2008, 08:34 PM   #7
Fraser
Fraser's Avatar
so, basically a regular hex head 12mmX1.75 bolt will work, w/ the proper grade rating
Old October 12th, 2008, 08:38 PM   #8
yeah, but it has like a 17mm hex head and REALLY sucks trying to loosen tighten
Old October 12th, 2008, 08:55 PM   #9
jeepxj_boy_21
linked
Originally Posted by Fraser View Post
your slackin
yea o well no point to try and get it done now.
Old October 12th, 2008, 09:01 PM   #10
Fraser
Fraser's Avatar
ahh, ok. didnt catch that from the other post
Old October 12th, 2008, 11:06 PM   #11
oz97tj
Wasn't this attached?
oz97tj's Avatar
17mm? I just got done putting an 8.8 in my TJ. I ended up using the stock bolts but while at Unlimited Offroad buying my flange adapter I bolt the bolts for it too because I didn't know if I had the stock ones still. They weren't that big. I didn't try them to see clearance issues, but I know they weren't 17 mm. I'm guessing 14 or 15 at most
********GLFWDA.org********
Page generated in 0.37245 seconds with 56 queries
