Explorer on 33's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2008, 07:10 PM   #1
94KOTA
Buy American!
94KOTA's Avatar
Send a message via AIM to 94KOTA
Default Explorer on 33's
how well would a explorer hold up with stock gearing 8.8 rear end and the A4LD tranny...with 33s.....lots of strain?
94KOTA is offline   Reply With Quote
Old October 12th, 2008, 07:11 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
what gears?
Old October 12th, 2008, 07:12 PM   #3
i do just fine with 3.73s........just make sure you have a large tranny cooler. The A4LD breaks down and grenades itself quick if you over heat it.
heres my 4dr with 3.73s 33's and A4LD
my truck is tired.......180K on motor and unkown miles on the trans
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Private Property
Old October 12th, 2008, 07:17 PM   #4
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
whats the axle code say on the door?
Bronco Ollie is offline   Reply With Quote
Old October 12th, 2008, 07:20 PM   #5
94KOTA
Buy American!
94KOTA's Avatar
not sure what the gears are...whatever stock is...its an Eddie Bauer if that helps..i can check the code tomorrow...can you buy larger tranny coolers? where? how much, easy install??
Old October 12th, 2008, 07:23 PM   #6
i got mine from napa, was like $50-60 and was pretty easy install once you pull the grille off. Tranny cooler is an absolute must with a A4LD even a stock truck needs a better one then the factory offered
Old October 12th, 2008, 07:24 PM   #7
Bronco Ollie
stock is all different here's the codes
Explorer 43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Old October 12th, 2008, 07:26 PM   #8
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
my code
or their is a tag ont he axle itself being held on by a diff cover bolt that says the ratio
my tag shows 3L73
Old October 12th, 2008, 07:28 PM   #9
Bronco Ollie
my b2 says d4 3:73's with l/s i gotta buy a tranny cooler for my A4Ld
Old October 12th, 2008, 08:44 PM   #10
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
i can vouch with a good tranny cooler and rad bypass an A4ld will hold up.. Im running 37s locked front and rear with 4.56s with a 4.0 and the a4ld..
Old October 12th, 2008, 08:56 PM   #11
88mudder
In the band!
yeah dude like what cheapthrills says 3.73 will do, 4.10's even better..if u have lower than 3.73 its going to be a dog and will want to regear. I have a 3.73 pig if ur interested in it.
Old October 12th, 2008, 09:04 PM   #12
xj97sport
atv rider
xj97sport's Avatar
YouTube Video
Private Property
i had a chance to go out there today .... ya i didnt get to far after the sand
Page generated in 0.30281 seconds with 59 queries
