2007 Tracker Pro Guide V-16SC boat - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2008, 04:53 PM   #1
hellajeepster
Throttled
hellajeepster's Avatar
Default 2007 Tracker Pro Guide V-16SC boat
50hp Mercury 2 stroke outboard, oil injected, less than 10hrs on motor
6hp Mercurt 4 stroke outboard, purchased new with boat last year
Full ratcheting Tracker boat cover
SPECS
Length 16' 2''
Beam 85"
Depth Inside 23"
Transom Height 20"
Bottom Width 69"
Max. Person Capacity 5 Persons
Max. Person Weight 720 Lbs.
Max. Weight Capacity 1275 Lbs.
Hull Material 0.090 5052 Marine Alloy
Weight (approx.) 1194 Lbs.
Fuel Capacity 24 Gallons
Pkg Length w/ Swing-Away 18' 8''
Package Width 7' 5''
Package Weight (approx.) 1895 Lbs.
Deadrise 19 degrees
FEATURES
Comfort, Safety, Convenience
Drink holders
Fire Extinguisher
Flotation meets or exceeds NMMA and U.S. Coast Guard requirements
Paddle
Passenger Grab Handle
Safety Lanyard
4 Cleats
Construction
All-Welded Two-Piece Hull w/19 Degree Deadrise
Silver Medallion w/Charcoal Graphics
Full-Length Longitudinal Stringer System
All-Aluminum Transom
Reverse Chine Hull Design
Transom Designed for Kicker Motor (gas or electric)
Heavy Duty Extruded Gunnel
Marine Tech Pressure Treated Floors And Decks w/Limited Lifetime Warranty
2 Performance Running Strakes
Dash / Console
Custom Molded Console
Console Designed for Large Graph or GPS Units
Tinted Plexiglass Windshield
Rack & Pinion Steering
Simulated Burlwood Instrument Panel
Navigational, Aerator, Bilge Toggle Switches
Electrical
12-Volt Trolling Motor Harness
Interstate® Cranking Battery
Interstate® Trolling Battery
Sheathed Electrical Wiring
500 GPH Bilge Pump
Stowable Navigation Lights
Courtesy Light in Bow Light
12-Volt Outlet
Electronics
Lowrance® X37 Fish Finder w/ Surface Temperature, Battery Monitor, and Swivel
Interior
Bow Storage
Elevated Bow Casting Deck
Aft Elevated Fishing Platform w/ Base
Aft Battery Storage
3 Deluxe Fishing Seats w/ Composite Frames
Seats w/ Pinchless Hinges
Upholstery is Standard w/ a Stain Resistant Top Coating
6 Pedestal Seat Base Locations
2 Lockable Top Loading Rod Boxes
Lockable Side Storage
Livewell Systems
23 Gallon 40" Bow Aerated Livewell w/Baitwell Insert, Pump-out and Timer
500 GPH Aerator Pump
Livewell w/Rounded Corners
Trailer
Color Coordinated Drive-On Trailer
Powder Coated Steel Tubing w/GalvaShield® Protection
EZ Lube Hubs
13" Tires and Wheels w/ Powder Coat Finish
Fold-Away Tongue Jack w/ Swivel Wheel
Heavy-Duty Winch w/Nylon Strap and Safety Strap
Non-Skid Fender Pads
Retractable Safety Cables
Roller Load Guides
Submersible Lights
Swing-Away Tongue
Transom Saver
Welded Tubular Frame
Trolling Motor
Minn Kota® 12-Volt, 42 lb. Thrust, 54" Shaft, Foot Control PowerDrive Trolling Motor
This is a perfect fishing boat and in great condition, stored indoors last winter, everything runs great, must sell $11,500
586-292-2486
hellajeepster is offline   Reply With Quote
Old October 21st, 2008, 05:09 AM   #2
hellajeepster
Throttled
top
Old November 28th, 2008, 08:10 AM   #3
hellajeepster
Throttled
bump
Old January 11th, 2009, 03:11 PM   #4
hellajeepster
Throttled
Its almost that time of year. Got it stored indoors waiting for someone to buy it.
Page generated in 0.15524 seconds with 35 queries
