Body lift help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2008, 01:06 PM   #1
billywilly92
billywilly92's Avatar
Default Body lift help
I was thinking of putting a 3 inch body lift on my 86 k20. I already have the lift blocks and bolts off of another truck. Is there anything I should know before I do this? Will I have to extend anything? What should I put between the bed and the frame?
I was also thinking about keeping the 35's on it until I can buy bigger tires, would this be unsafe since it would be taller?
billywilly92 is offline   Reply With Quote
Old October 13th, 2008, 11:21 AM   #2
billywilly92
42 views and no one knows. Im sure theres a lot of you who know how to do this
Old October 13th, 2008, 11:49 AM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I would NEVER do anymore than 1" on a body lift. There is going to be a lot of flex on those mounts.
You will have to move your radiator fan shroud, move the radiator down (or move the engine up). Extend the breathers for axles, transfercase, and trans. Probably need to play with the hard brake lines coming off the master cylinder.
Old October 13th, 2008, 11:55 AM   #4
88mudder
In the band!
ive never done a body lift on a k20, but most older trucks are really straightforward and easy. Most the time the fan shroud will need to be modified. Shifter linkage might need adjusted or lengthened, and E-brake cable will get stretched. Hockey pucks work good for spacers on the bed, just drill a hole in the centers, stack 3 high for 3".
Old October 13th, 2008, 12:57 PM   #5
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
You should take those lift blocks and bolts and place them in a box on the shelf until you can pawn them off on someone else. Body lifts = never a good idea
Trim you fenders to run bigger tires and be far better in the long run
Nuzzy is offline   Reply With Quote
Page generated in 0.23856 seconds with 38 queries
