valve cover breather leaking oil - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2008, 06:12 PM   #1
PHATS79
PHATS79's Avatar
Default valve cover breather leaking oil
I hav a stupid problem thats more annoying than a problem. got a big block chevy and my valve cover breathers both leak oil out of them, they also have a little smoke come out of them when the motor gets up to temp. Is this an issue with my valves, or would new breathers fix the problem???
PHATS79 is offline   Reply With Quote
Old October 10th, 2008, 07:31 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like you eliminated your PCV valve? if so put one back in the system. it creates just enough vacuum to keep the oil in. secondly if your valve cover vents are puking oil then your oil return holes at the back of the heads maybe plugged? I have seen crap piled in the holes or head gasket material blocking them.
Yetti
Old October 10th, 2008, 09:17 PM   #3
s.hembree
s.hembree's Avatar
Do you have baffles in the covers or in the breathers?
Old October 10th, 2008, 10:41 PM   #4
PHATS79
PHATS79's Avatar
there are baffles in the breathers i believe
Old October 10th, 2008, 10:44 PM   #5
PHATS79
PHATS79's Avatar
i will take the covers off and check the holes tomorrow, i doubt they are blocked though, the heads have maybe 10 hrs on them, just had the valves re-adjusted
Old October 13th, 2008, 04:13 AM   #6
2kids=nojeepmoney
see the first reply. doesn't sound like you have a PCV installed.
2kids=nojeepmoney is offline   Reply With Quote
Page generated in 0.17940 seconds with 41 queries
