t-case ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2008, 08:48 PM   #1
JEEPS
92 xj
JEEPS's Avatar
Send a message via AIM to JEEPS
Default t-case ?
ok i am lookin for a tcase with a drivers drop that i can put a twin stick on it or would it be eaiser to bu the dana 300 and get the drivers drop case from stak or retube the axle so it is a passenger drop
JEEPS is offline   Reply With Quote
Old October 9th, 2008, 10:35 PM   #2
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
$60 clocking ring to flip the 300 180* as another option...
Nuzzy is offline   Reply With Quote
Old October 9th, 2008, 10:43 PM   #3
JEEPS
92 xj
JEEPS's Avatar
Were would I get the 60$ clocking ring at so I can run it up side down
Old October 9th, 2008, 10:49 PM   #4
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
at the store......
did u try a search??
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old October 9th, 2008, 11:02 PM   #5
Nuzzy
Nuzzy's Avatar
http://www.greatlakeoffroad.com/clock.html
"This ring will lay your Dana 300 transfer case flat and are 3/8" thick.
Just what you need for that added ground clearance.
All hadware included.
$67 Shipped TYD lower 48**"
Old October 9th, 2008, 11:14 PM   #6
JEEPS
92 xj
JEEPS's Avatar
So this ring will let me run it up side down to turn it in to a drivers drop
Old October 9th, 2008, 11:20 PM   #7
Nuzzy
Nuzzy's Avatar
It should allow you to flip the case, yes. And the 300 is an oil slinger so it should lubricate fine. However, you would need to consider fill/drain plug and proper oil amount. Also, seems most people I've seen do this go to cable shifted twin sticks since it's easier to route and mount them.
It has definitely been done before though with success. Search around and I'm sure you'll find a write up.
Old October 9th, 2008, 11:26 PM   #8
JEEPS
92 xj
JEEPS's Avatar
Thanks nuzzy. U. Help me out a lot u answer a lot of my ? And I really apprecate it
Old October 9th, 2008, 11:34 PM   #9
Nuzzy
Nuzzy's Avatar
http://www.pirate4x4.com/forum/showt...ipped+dana+300
Old October 9th, 2008, 11:39 PM   #10
Nuzzy
Nuzzy's Avatar
Just make sure to read up on it as much as you can before making any decisions. I only know that it's been done, so I know it can be done. However, every application is specific. An XJ with an auto may be slightly different fitting than an XJ with a manual, or a TJ, or...
The links I posted were just some of the first to pop up when searching Pirate. Read as much as you can about ALL your options so there is as little surprise as possible. There may very well be better solutions out there
Page generated in 0.27093 seconds with 53 queries
