Ford Explorer SOA?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2008, 02:14 PM   #1
94KOTA
Buy American!
94KOTA's Avatar
Send a message via AIM to 94KOTA
Default Ford Explorer SOA??
Hello,
thinking about doing a spring over on a 94 Explorer with blocks for a 6 inch lift then get all the other brackets, pitman, coils for the front....just wondering if any one has done a SOA on an exploder...need for ladder bars, does it change driveshaft angles alot??? any important information i should know???
Thanks
Nick
94KOTA is offline   Reply With Quote
Old October 7th, 2008, 02:31 PM   #2
soa in the rear will give you pretty much 6"s with no blocks .....i only have a SOA in the rear on my 4dr and have no problems with the stock driveshaft or axle wrap. but when you weld the new perches i would add a little for the pinion angle.
Old October 7th, 2008, 08:59 PM   #3
94KOTA
Buy American!
94KOTA's Avatar
do they sell perches made up already for the 8.8??
Old October 7th, 2008, 09:09 PM   #4
yeah axle tube is 3.25"
Old October 7th, 2008, 09:11 PM   #5
88mudder
In the band!
hey man, check out www.ruffstuffspecialties.com
Old October 8th, 2008, 09:51 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
i believe superlift makes a bolt on kit that doesn't require weldeing
Old October 8th, 2008, 09:02 PM   #7
94KOTA
Buy American!
94KOTA's Avatar
i want to get rid of spring under...gets hung up too easily...
Old October 8th, 2008, 09:46 PM   #8
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
and they look much better lifted
Bronco Ollie is offline   Reply With Quote
Old October 9th, 2008, 09:57 AM   #9
fsumotorhead
N8KVB
Here's a pic of the non-weld on type
Seems like it would work just fine
Old October 9th, 2008, 04:41 PM   #10
94KOTA
Buy American!
94KOTA's Avatar
is that a block??..with add a leaf?
Old October 10th, 2008, 07:08 PM   #11
88mudder
In the band!
its the non-welded SOA kit, easy to install. The ubolts hold it all together..and has the lower shock mounts right on em.
Old August 16th, 2012, 07:55 PM   #12
goin for 35"
Default soa rear blocks for explorer, where can i find!!?
where can i find those? and how muck?
goin for 35" is offline   Reply With Quote
Old August 16th, 2012, 08:05 PM   #13
goin for 35"
where can i find the non- weld soa blocks
Old August 16th, 2012, 08:06 PM   #14
masterbeatty
masterbeatty's Avatar
google.com
Old August 16th, 2012, 08:08 PM   #15
goin for 35"
i did google didnt find, now im here asking !!! where this person got them
Old August 16th, 2012, 08:29 PM   #16
mudrunner78
mudrunner78's Avatar
http://4wheelonline.com/Products.asp...roductId=66083
mudrunner78 is offline   Reply With Quote
Old August 16th, 2012, 09:15 PM   #17
NewGuy
I just got my 94 explorer up and running from doing a SOA and James duff parts in the front. You will get 5-6" just doing the soa, no need for blocks.
I would stay away from that super lift kit. I looked into it and alot of people have had it pulled it off due to to much noise from it moving around while driving. Also not worth the money. I bought a set of balistic fab leaf spring perches and shock mount conversion brackets and have about 100 into parts including new shackels. And couldn't be happier with the ride even with a set off bad rear shocks.
NewGuy is offline   Reply With Quote
Old August 16th, 2012, 09:16 PM   #18
NewGuy
I will see if I can get a pic of my explorer on here to see how it sits
Page generated in 0.35970 seconds with 77 queries
