help quad runs like crap! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2008, 04:50 AM   #1
The-Sandman
Real jeeps are built...
The-Sandman's Avatar
Default help quad runs like crap!
I have a 99 kawaski praire 2wd 400 quad...
I use it very little, only for yard work and stuff
for the past couple years it would run great for about 10-15 min and then when it got warm it would just spit and sputter and backfire...and usually die, even when feathering the throttle or having it wide open...wait a couple minutes and it would run again for 4-5 minand then do it again
now it wont even run for 2 min...
carbs are cleaned and look good, i did find a bad plug wire end...repaired the plug wire and replaced the end (wire a little shorter now)
and there is no change....
I dont want to take this to a dealer, any ideas?
I am thinking the bad wire caused the coil to get weak and it breaks down when it gets hot???
any other ideas? am I way off my thinking?
The-Sandman is offline   Reply With Quote
Old October 7th, 2008, 08:19 AM   #2
Cartman
Can't lose with 42s
Cartman's Avatar
Check stator, cdi and coil..you are on the right track!! It sounds like an electrical problem to me
Cartman is offline   Reply With Quote
Old October 8th, 2008, 02:40 AM   #3
The-Sandman
how would i test them?
Old October 8th, 2008, 03:13 AM   #4
jeepguy74
jeepguy74's Avatar
first off i would do a compression check.... if it is lower after it warms up you may have gummed up rings or even bad rings you can use some marvel mystry oil in the cylender and let it soak or some wd 40...dunno if this will help you or not just my 2 cents
Old October 8th, 2008, 09:46 AM   #5
gmotox
gmotox's Avatar
first off check the gas tank breather if it has one, next check to make sure it has good fuel flow from the gas tank.
Old October 15th, 2008, 11:57 PM   #6
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
stupid question but is the choke stuck hey ive seen dumber things. you can use one of those fancy spark testers. if i had to guess other than carbs(choke) id say stator
Old October 16th, 2008, 01:45 AM   #7
The-Sandman
No the choke is working fine it is not stuck on, the carbs were just cleaned(by a professional), cause i thought that is what was wrong with it
i use this alot in the fall...so i am babying it and it seems to run ok if i dont try and run it hard....if i just putt around under half throttle it seems to stay running...i try and run it hard and after a few minutes it spits and backfires and falls on its face, but not right away???
when i get the money i am taking it to a kawaski dealer
Old December 17th, 2008, 08:58 PM   #8
bikerted86
Does it pop through the carb when in cuts out or through the exhaust. It could be a air leak causing it to run lean, Try spraying around the carb and carb boot with carb clean and see if the idle changes.
bikerted86 is offline   Reply With Quote
Old December 17th, 2008, 09:09 PM   #9
OLBLUE
OLBLUE's Avatar
Send a message via Skype™ to OLBLUE
Cool
try running a hotter plug my 200x did that ran a hotter plug now it runs great
OLBLUE is offline   Reply With Quote
Old December 17th, 2008, 09:45 PM   #10
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you boys awt to know better then to drag out old posts...shame shame.
Yetti
Page generated in 0.29256 seconds with 53 queries
