4.3 vortec - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 6th, 2008, 04:14 PM   #1
MTY Mouse
MTY Mouse's Avatar
Default 4.3 vortec
_Post for my father in law_
Is it possible to have a 4.3 vortec dist off a tooth?
Installed new crate motor and not getting the mileage was before and slight shake when at idle.....
Please help!
MTY Mouse is offline   Reply With Quote
Old October 6th, 2008, 06:06 PM   #2
Cartman
Can't lose with 42s
Cartman's Avatar
I'd check vacuum lines first. If its TBI remember to check the timing you will need to short the pins out on the connector, just like you are reading trouble codes.
Cartman is offline   Reply With Quote
Old October 6th, 2008, 08:09 PM   #3
MTY Mouse
MTY Mouse's Avatar
I will forward him that info
Thanks
Old October 6th, 2008, 09:57 PM   #4
GetItOffroadGMC
GetItOffroadGMC's Avatar
He will need to have the timing set with a scanner. But yes you can be a tooth off. You will also need to have the crank variation reset.
If this is an OBD 2 system.
GetItOffroadGMC is offline   Reply With Quote
Old October 7th, 2008, 07:10 AM   #5
MTY Mouse
MTY Mouse's Avatar
not sure if this tells if it is the system you are referring to but, It has the cap on it where the wires go out to the side and the distributor has a pin that locks it in only one position so it can not be turned.
Page generated in 0.19049 seconds with 38 queries
