s10 v8 build ???'s - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2008, 09:33 PM   #1
methodx55
methodx55's Avatar
Send a message via AIM to methodx55
Default s10 v8 build ???'s
Im think about getting a 350 or 383 sbc with a th350 trans for my 97 2wd s10
What kind of mods do i have to do to make this thing fit??
im obviously going to need new radiator, mounts and other obvious things but is there any other hiden things i might have to worry about?
methodx55 is offline   Reply With Quote
Old October 5th, 2008, 10:43 PM   #2
GetItOffroadGMC
GetItOffroadGMC's Avatar
motor mounts, headers, and an oil pan for the 4x4s. I know the pre 93s you had to do a lil fire wall beating for the distrubtor.
GetItOffroadGMC is offline   Reply With Quote
Old October 5th, 2008, 10:46 PM   #3
454 jeep
454 jeep's Avatar
It's a pretty simple conversion. You'll have to move the motor mounts and re-drill the cross member. There's a ton of after market parts to make it a snap.
454 jeep is offline   Reply With Quote
Old October 5th, 2008, 11:04 PM   #4
methodx55
methodx55's Avatar
yea i saw some bolt on mounts for it, it takes out the chance of me screwing it up
Old October 5th, 2008, 11:04 PM   #5
methodx55
methodx55's Avatar
what about the trans?
Old October 5th, 2008, 11:09 PM   #6
454 jeep
454 jeep's Avatar
350 turbo. That way you can find a factory shaft that will work.
Old October 5th, 2008, 11:13 PM   #7
methodx55
methodx55's Avatar
any mods in that place?
Old October 6th, 2008, 01:02 AM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
if you run a 700r4 you can use stock shafts
Old October 6th, 2008, 07:39 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what engine/trans was in it stock? i've got a 350 in my 95. it came with a 4.3 and 5 speed. the 350 was a direct bolt in. used all stock accessories, radiator, trans. the engine sits in stock location and did not require firewall bashing. i made my own hard mounts by taking the 4.3 frame side mounts, switching sides and bolting them down. then i bolted the block mounts to them. the only other change is i used a mechanical reverse rotation flex fan with no spacer bolted to the water pump. trucks runs at 180 all day unless i'm idling in traffic then it'll see 210. i plan on getting a small electric fan to assist with that.
Old October 6th, 2008, 08:26 AM   #10
jbsjunk
Little Member
jbsjunk's Avatar
http://www.v8s10.org/forum/index.php
jbsjunk is online now   Reply With Quote
Old October 6th, 2008, 08:34 AM   #11
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
Some of those mounts cause the engine to sit too far forward making certain header combos not fit between the starter and frame/engine crossmember. If you need any pics let me know. I have an '86 and my neighbor has a '97-8 with a 406.
Red68Camaro is offline   Reply With Quote
Old October 6th, 2008, 12:25 PM   #12
methodx55
methodx55's Avatar
stock engine/trans is 2.2l auto
Old October 6th, 2008, 12:26 PM   #13
methodx55
methodx55's Avatar
yea, lets see some pics
Old October 6th, 2008, 02:13 PM   #14
Red68Camaro
Let me clean it up a little....she's been neglected the last few years I'm embarrassed to show it.........
Old October 6th, 2008, 06:30 PM   #15
Tom
Because racecar
Tom's Avatar
you should sell him that truck
Old October 6th, 2008, 09:11 PM   #16
methodx55
methodx55's Avatar
well clean it
Old October 6th, 2008, 09:12 PM   #17
methodx55
methodx55's Avatar
put too much in this truck to change it
Page generated in 0.27944 seconds with 74 queries
