RickyBuilt Jeep XJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2008, 08:40 PM   #1
jeepnxj96
jeepnxj96's Avatar
Default RickyBuilt Jeep XJ
So I guess i'll make this the official start of my new rig build up.
step 1: Drag my dads 88 MJ out of the way
step 2: Drag my 92 XJ out of the weeds
plans
build a full cage inside
take suspension from my 96 and swap to the 92 and make the control arms about 6" longer and stronger mounts
strengthen rear leaf spring hangers and unibody
swap OBA over to 92
Line-x the crap out of underbody and interior
swap drive train over and add a new header, 99+ intake, and new rearmain seal (after rig is wheelable i will attempt a stroker build, have most parts for that now!!!)
finish my rear bumper and tire carrier and move hi-lift to tire carrier
install 8.8 rear end and 4.11's
install lunch box locker in d30 and wheel till it explodes
Old October 4th, 2008, 08:42 PM   #2
jeepnxj96
jeepnxj96's Avatar
Old October 4th, 2008, 08:45 PM   #3
jeepnxj96
jeepnxj96's Avatar
very little rust on this one as opposed to my 96. so starting with a solid platform, well as solid as a unibody can be anywayLOL
Old October 4th, 2008, 09:28 PM   #4
greatpumpkin
Newbie No More
greatpumpkin's Avatar
If you ever need help ,call me as much as you've helped me, I need to return the favors
greatpumpkin is offline   Reply With Quote
Old October 5th, 2008, 04:14 AM   #5
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Yep, I'm definitely gonna need to stop by to check up on this build
Nuzzy is offline   Reply With Quote
Old October 5th, 2008, 08:04 AM   #6
jeepnxj96
jeepnxj96's Avatar
what you think I need a supervisor or something
probably. I got to finish guttin the 92 so i can see how much body work needs to be done inside, I know it is very little, but I want a jeep I can wheel for another 8-10 years and not have to worry about rust on key componets.
Old October 5th, 2008, 12:21 PM   #7
Nuzzy
Nuzzy's Avatar
I hope not, cause I make for a horrible supervisor
Old October 5th, 2008, 01:50 PM   #8
jeepnxj96
jeepnxj96's Avatar
awsome me too
Old October 5th, 2008, 04:53 PM   #9
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Looks like it's gonna be a pretty cool process to watch. You should ditch the thornbirds tho, definately not very fond of those tires. Have fun.
bitchofanxj is offline   Reply With Quote
Old January 27th, 2009, 09:18 PM   #10
jeepnxj96
jeepnxj96's Avatar
well gotta a chance to work on the jeep now, not much done but managed to get the dash pulled out and get the main hoops bent up for the cage and mocked into aproximate locations, plan on cutting stringers and tacking it together tommorrow. let me know of any concerns you might see, this is my first cage and I am pretty much shooting from the hip LOL
Old January 27th, 2009, 09:22 PM   #11
jeepnxj96
jeepnxj96's Avatar
the hoops are just in rough proximity,tommorrow I will cut my stringers and move rear hoop where I want it and tack everything together.
Old January 27th, 2009, 09:25 PM   #12
xj97sport
atv rider
xj97sport's Avatar
needs rims and tires
Old January 28th, 2009, 09:11 AM   #13
Waychoff05
Waychoff05's Avatar
prolly come down later to help out or watch and give you a hard time!!
Waychoff05 is offline   Reply With Quote
Old February 21st, 2010, 10:53 AM   #14
jeepnxj96
jeepnxj96's Avatar
Well I finally got a chance to work on this one again...........not much progress but some none the less, hopefully will be able to find some more time to knock out a little more. After a little head scratching and brain storming we finally decided against welding floor plates directly to floor. Instead the floor will be sandwiched between to 1/4" plates bolted together and will allow me to tie in to the unibody as best as I can. Thanks to Bigblockford79 for coming out and helping and for the ideas
not much structure on the wheel well, but need a place for this hoop, I will run a floor plate that will span the width between the wheel wells and tie in to that with some down bars, I wanted this hoop here so I could put a harness bar in for the rear seat.
hopefully I can get some more done later.
Old February 21st, 2010, 10:58 AM   #15
xj97sport
atv rider
xj97sport's Avatar
looks good ... you need a bigger garage tho ... then again so do i
Old February 21st, 2010, 11:06 AM   #16
jeepnxj96
jeepnxj96's Avatar
we all need bigger garages, but it works for me and I am not outside, so it'll do LOL
Old February 21st, 2010, 11:10 AM   #17
xj97sport
atv rider
xj97sport's Avatar
ill have to make a trip out there and check it out sometime, i lost ur number when my phone broke ... ill have to get it from ya again
Old February 21st, 2010, 11:40 AM   #18
pistol pete
I do vinyl stickers
pistol pete's Avatar
man those first couple of pics made my cabin fever worse that it already is. i cant wait to see grass like that again. nice looking project the cage is looking good
pistol pete is offline   Reply With Quote
Old February 21st, 2010, 12:00 PM   #19
jeepnxj96
jeepnxj96's Avatar
thanks..............I wish it was done......that is the problem with have a wheeling rig already, spent to much time playing and not enough time building the other.
Old May 25th, 2010, 08:57 PM   #20
jeepnxj96
jeepnxj96's Avatar
well I have learned that cages, XJ's, and mounting suspension seats to said cage, are not much fun.........so here is the disaster I am working on and hopefully after I get this done, every thing else will go easier..........yeah right
had to clearance the tranny tunnel to fit my seats and cross bars for the cage to mount the seats too.
yes this build is going incredibly slow........but work is really busy right now..... I also hate sheetmetal work LOL
Page generated in 0.58073 seconds with 83 queries
