***SOLD*** 4L60e with Dana 300 adapter $500, also 4.3MPFI V6... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2008, 08:32 PM   #1
Default ***SOLD*** 4L60e with Dana 300 adapter $500, also 4.3MPFI V6...
SOLD
This is a 1999 4L60e, with a Novak Dana 300 adapter on it.
Was given a basic rebuild when the adapter was installed in it. Adapter is brand new. If it matters to you, it came from a suburban with a 350. This is a 6 bolt hex style.
The Dana 300 adapter is clockable, I believe there are 3 or 4 options from a stock angle up to flat.
Note, these later 4L60e's are shorter than earlier ones, so would fit well in a SWB Jeep. Same length as a TH350/D300, actually.
$500 Firm. Will not sell the adapter separately (because it would require the trans to be disassembled!!)
This is less than the price of adpater alone.
Would consider partial or full trades for Wagoneer axles (passenger drop) or 36-38" swampers in good shape.
Also have a 1999 4.3 Vortec V6 with more or less all the parts (needs a water pump), for $300. Around 150k miles, IIRC. The pair would match well in a Jeep.
Here's pics of the trans:
Haggar is offline
Old October 5th, 2008, 08:54 AM   #2
chevotass
chevotass's Avatar
this is without the 300 correct?
chevotass is offline
Old October 5th, 2008, 10:19 AM   #3
Correct, trans + adapter only, no t-case.
Haggar is offline
Old October 5th, 2008, 10:51 AM   #4
chevotass
chevotass's Avatar
what spline will it fit? is it setup to fit a stock 300? or does it need a 300 with a different input gear? have reciepts for rebuild of trans? any warrenty?
Old October 5th, 2008, 12:03 PM   #5
Bolts to a stock 300.
As for the receipts, no, I bought it as is from another member of this board who was parting out an incomplete project.
Haggar is offline
Old October 6th, 2008, 01:10 PM   #6
ttt
Haggar is offline
Old October 6th, 2008, 01:23 PM   #7
0llllll0
JeepJohnson
0llllll0's Avatar
Couldn't you also bolt up a 231 J or D to it with that adapter as well ? I think you can but not 100% sure...
Jeepjohnson
"Black Foot" my CJ-7 build
Do you have a YJ ? Is the rear Frame rusted ? Check this out YJ Rear Frame Reinforcement Plates
0llllll0 is offline
Old October 6th, 2008, 02:25 PM   #8
Dunno.
Haggar is offline
Old November 20th, 2008, 02:58 PM   #9
bump
Haggar is offline
Old November 23rd, 2008, 07:29 PM   #10
builtyj
Default 4l60
do you still have this?? would you happen to need anything on trade???? 465/300 combo
builtyj is offline
Old November 23rd, 2008, 08:02 PM   #11
I've already got a 465/300 in the Jeep. Not really anything I need in trade.
I still have the trans, though, yes.
Haggar is offline
Old November 27th, 2008, 08:17 AM   #12
YooperMog
What is the total length?
YooperMog is offline
Old November 27th, 2008, 09:20 AM   #13
of the trans + adapter?
24.6"
Note that a TH350 with adapter is 24.8", so it isn't any longer for the much better first gear and 30% overdrive.
Haggar is offline
Old December 21st, 2008, 06:43 PM   #14
sold!
Haggar is offline
Page generated in 0.34629 seconds with 65 queries
