John's Foreign Engine Samurai 1.3 1500 miles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 2nd, 2008, 09:20 AM   #1
Rubilooe
Rubilooe's Avatar
Default John's Foreign Engine Samurai 1.3 1500 miles
I have a barely Used 1.3 (1500 miles )Rebuilt Engine from John's Foreign Engines.This is being sold as a long block ,it will have the oil pan valve cover and water pump included . RV2 Cam ,3 Angle Valve Job,Decked ,Bored,Tanked,Line Bored,Flat Top Hi Compression Pistons,Lots of high quality work done. Very Good Condition. 800.00 . Also have a custom intake manifold and 38 mm Weber with custom aircleaner Built by ''SARGE'' 350.00. I will sell Engine and Intake Carb Setup together for 1000.00 Thanks I have a ton of great Samurai from good tub to lifts .
Rubilooe is offline   Reply With Quote
Old October 2nd, 2008, 11:30 AM   #2
millersracing
Dare to follow me???
millersracing's Avatar
Why are you selling it? Also do you know about how much more power it has now over a stock motor?
millersracing is offline   Reply With Quote
Old October 2nd, 2008, 03:55 PM   #3
Rubilooe
Rubilooe's Avatar
Going Propane on my build using a 91 EFI 1.3. You can go to John's Foreign Engine website this is the premium build. Thanks
this engine is capable of producing 90-100 horse power with the right carb header and exhaust
Old October 3rd, 2008, 07:35 AM   #4
millersracing
Motor sounds pretty close to what i want to build, i'll let you know later. Money's a little tight at this time. Maybe after the first of the year if its still around.
Old October 12th, 2008, 10:59 PM   #5
stomperz71
Zuk-Mon
stomperz71's Avatar
You won't get that kind of power out of EFI or propane. I'm running a built 1.3 bored .040" over, 1.6 head shaved, Isky Cam, 1.6 Intake, header, Hybrid EFI throttle Body. Not sure what horse I'm getting at the crank but had it on the dyno this spring and it had 60 horse at the rear wheels. That's with 5.14:1 t-case gears, 4:57 axle gears and 33" Swampers. Alot of rolling resistence right their!!
I can tell you the EFI runs a whole lot better then a carbed Zuk, which propane will run alot better then a carb also.
stomperz71 is offline   Reply With Quote
Tags
1.3, engine, john's, samurai
Page generated in 0.28885 seconds with 38 queries
