Widening a trailer ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2008, 09:40 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Widening a trailer ??
What's the Legal on widening a trailer ??
I think it's 101" max width ??
i just plan on bumping the deck out to the same width as the fenders so i think im good there.. i just want to be able to put 2 quads next to each other on the back..
these are really the best shots i have of the trailer.. its a 18' USA trailer sales Car hauler.. 2' beavertail..
I plan on widening it from right behind the fenders to the end of the trailer..
Old September 30th, 2008, 09:49 PM   #2
boggin-machine
boggin-machine's Avatar
do it. nothing to it. id use 2x4 or something similar at a 45 to the width taht your looking for. sorta like a triangle down the side and weld on the metal or wood that you want to use. sounds easy and will be more then strong enough to support a wider truck or the quads that you will be hauling. i tend to over build things and make them to heavy so any tubing will work. or bend up some schedule 40 tubing at work ad do it that way. easy to do it.
Old September 30th, 2008, 09:52 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
never thought about doing it with tubing... i was gona do C channel thats what the rest of the trailer is made of..
Old September 30th, 2008, 09:54 PM   #4
boggin-machine
be a cheap way to do it. seen it done once before i think and it turned out well for widing a trailer. thats what i would do.
Old September 30th, 2008, 10:42 PM   #5
dune coon
do work
dune coon's Avatar
how do you weld wood?
dune coon is offline   Reply With Quote
Old September 30th, 2008, 10:44 PM   #6
boggin-machine
ok sorry. screw down the wood of choice.
Old September 30th, 2008, 10:53 PM   #7
littleredzj
i like turtles.
littleredzj's Avatar
dude, you've never welded wood before. you just gotta pre-heat it good with a torch then you can weld it tig, just make sure you use sticks from the same kind of tree for filler rod
littleredzj is offline   Reply With Quote
Old September 30th, 2008, 11:13 PM   #8
Blackjackbender
i wanna say legal width is 108"
Old September 30th, 2008, 11:17 PM   #9
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Hmm.... I could be wrong, but I always thought 103"? Maybe I should look it up.
Old September 30th, 2008, 11:24 PM   #10
Ridin Dirty
Ha! Looks like we're all wrong... it's 102".
Old October 1st, 2008, 04:38 AM   #11
busyfixin
Balls Deep
busyfixin's Avatar
haha, i was thinkin you guys were all morons. you had it surrounded!
Old October 1st, 2008, 05:50 PM   #12
Yota Bill
you first need to drive a bunch of nails into the wood, and then paint it with the fake chrome stuff, but dont use the cheap paint, the high dollar stuff has more metal in it....oh, and keep a bucket of water handy, in case the wood catches on fire...
Old October 2nd, 2008, 12:48 AM   #13
hillbillyrockstar
Country folks living LOUD
hillbillyrockstar's Avatar
Location: from St. Clair County, working in Baltimore MD for a while
Here's what I'm working with. It's old, it's ugly, but its heavy duty as fawk. Tires are a dime a dozen mobile home Load Range E tires, and they use the old donut rims still.
And yea, 102 is the magic numba. I'd like to widen my trailer so it's around 7.5'-8' wide (90-96"). The reason I want it wider, is becuz the axles I'm using are fullwidth 60's, and the WMS on them is 69", well I measured one of the 44s I had sitting there, and from the WMS on the rim, to the outside of the tire is 9", so I added 18" (9" per side) to the 69" axle WMS-WMS width, and came up with 87" wide. I figure if I can take the trailer out another 4 or so inches beyond that, I'd be happy, for different width rims and tires and since I'm lookin at possibly doin Rockwells on down the road.
Hopefully this winter, maybe next spring, I plan on tearing the trailer apart and rebuilding it and doing kind of like you're saying with widening it. That's the only problem with it right now. As you can see, the frame on the trailer needs some TLC baaaad, or just a full rebuild / replacement.
And here's a trailer similar to ours, cept with a C-channel frame, and tubing for the parts he widened it...actually it's very similar though to what I'd like to do. Cept' I'd like to have fenders. Either driveover type, rubber, or a removable type. I'm also a big fan of the school bus....
Hope this helped ya see what tube might look kinda like....
hillbillyrockstar is offline   Reply With Quote
Old October 2nd, 2008, 11:12 AM   #14
PavementPounder
PavementPounder's Avatar
Make drive-over fenders.
JCR did my old trailer that I SOA'd, if anyone ever saw it. Atakrator here on GL has it now. They did a great job, too. Took the entire length of the deck out to the edge of the fenders, made me some nice & strong drive-over fenders that were framed with square tube, recessed all the lights, and beefed up the tongue a lot. I think every trailer I own in the future will have drive-over fenders like that one did.
It was the perfect height to tow behind my Ram. I miss it.
Old October 2nd, 2008, 01:57 PM   #15
hillbillyrockstar
Any pics of your old trailer?
Old October 6th, 2008, 10:13 PM   #16
Mclovin
"The Situation"
Mclovin's Avatar
I just wana widen it behind the fenders.. so i can put 2 quads side by side on the back behind the s10.. will prob have to put the s10 on backwards though to keep from too much tongue weight...
Old October 6th, 2008, 10:21 PM   #17
GetItOffroadGMC
GetItOffroadGMC's Avatar
Ive been thinking of having some tube bent for fenders, then I have some conveyor belt to lay over it.
Good idea??
GetItOffroadGMC is offline   Reply With Quote
Old October 8th, 2008, 08:20 PM   #18
hillbillyrockstar
Good idea??
Yea, I've seen that done a lot.....as long as the conveyor belt is good thick shit, you should be fine.....
Old October 8th, 2008, 08:49 PM   #19
Bones
Bones's Avatar
Hell, I would just use Schedule 40 and a Harbor Freight Kinker.
no need to pay someone with a tube bender or to pay for HREW
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 8th, 2008, 09:24 PM   #20
dodger889
dodger889's Avatar
In some states the 102 are only allowed on US federal hi-ways and interstates systems.
Page generated in 0.35445 seconds with 83 queries
