sealing threads - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2008, 08:15 PM   #1
88mudder
In the band!
Default sealing threads
i have a Transdapt remote oil filter system on a v8. The kit is great, but i'm having problems with leaks at the threads where the fittings screw into the block adaptor. Teflon tape has FAILED so far..can somebody give me some advice on what to use?
Old September 30th, 2008, 08:21 PM   #2
curt1656
Praise the lowered
curt1656's Avatar
Go to a plumbing supply and get some "Gimme the green stuff" pipe dope.
Old September 30th, 2008, 08:33 PM   #3
Shotgun
I only wheel with boats.
Shotgun's Avatar
JB weld, works great for spark plugs.
so one guy said
Old September 30th, 2008, 08:47 PM   #4
88mudder
In the band!
isn't this a household pipe sealant? Ive tried some plumbing dope yellow but it sucks..ive heard Permatex thread sealant is good. Any experiences?
Old September 30th, 2008, 08:50 PM   #5
rubicon
Are they AN Fittings?
rubicon is offline   Reply With Quote
Old September 30th, 2008, 08:50 PM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
My guess is that you are using pipe threads in a hole that has tube threads or the other way around. Ask me how I know about this.
Old September 30th, 2008, 09:04 PM   #7
88mudder
In the band!
no, barbs with rubber hose and clamps
Old September 30th, 2008, 09:05 PM   #8
88mudder
In the band!
hmm..
Old September 30th, 2008, 09:47 PM   #9
bigblockford79
Big Block Ranger
bigblockford79's Avatar
try different fittings. I have one of these remote set-ups on my V8 ranger and it hasn't leaked yet. I bought the 2 blocks from summit separate and got my own brass fittings from an idustrial plumbing supply store and they have never let me down. The problem with some fittings, especially the cheapos that those kits come with, is that a lot of the time the taper is off or the actual OD of the thread is smaller than it should be. This allows the fitting to thread all the way to the end of the threads and never make a seal. The other thing you might have going on is that if the block isn't new, the person before you may have overtightened the fitting before and opened the hole up a little.
BTW, they are pipe threads if you are using the permacool kit.:) 3/8 NPT if I am remembering correctly.
Old September 30th, 2008, 09:50 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Try using the liquid teflon sealant..
Old September 30th, 2008, 09:51 PM   #11
88mudder
In the band!
i got the transdapt kit. I went out to brinkers plumbing supply and bought new fittings, not the cheapos. I firmly think the sealint that i am using is the wrong type. Im going to try Permatex thread sealant tomorrow.
Old October 1st, 2008, 06:49 PM   #12
88mudder
In the band!
what I did was use Permatex thread sealer, then wrapped teflon tape around it then a coat of sealer. Apparently it takes 4 hours to cure, 72 hours to dry all the way Its been 8 hours so far..should i wait the full 72 hours?
Old October 2nd, 2008, 05:05 PM   #13
joe_jeep
welfare wheeler
joe_jeep's Avatar
if it dont work try hylomar. permatex and other companys make it. ive used it ot seal many bolts. works good on head bolts going into a water jacket.
Old October 2nd, 2008, 05:07 PM   #14
88mudder
In the band!
thanks. So far the method i used hasnt leaked at all. We will see..
Old October 6th, 2008, 08:40 PM   #15
88mudder
In the band!
the teflon paste + 2 wraps of tape worked good no leaks there...
I do still have a leak tho. Right where the ruber hoses clamp to the barbed fittings i cant seem to get it to stop leaking. Any tips on what to do? I was told to just get hydraulic -8AN hoses made..but thats way out of my price range right now.
Old October 6th, 2008, 10:58 PM   #16
Yota Bill
use red loctite on the barbed fitting...it will make the hose swell slightly, and then the loctite will cure and swell slightly also...I do this with all barbed fittings, and never have any leaks that way...
or you can find some fittings to go from NPT to a double flared, and make steel lines for the whole thing (brake lines)
Page generated in 0.30535 seconds with 71 queries
