03 tahoe issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2008, 03:08 PM   #1
MTY Mouse
MTY Mouse's Avatar
Default 03 tahoe issue
Have a noise in the driver side rear, related to the rear coil spring?? can feel it in the floor boards as well......when hit small bumps sounds like metal on metal errr e, errrr e, errr e type of noise, kinda like when you were is college with that chick from the bar.... Anyone out there ever have issues with the rear supension on there tahoe? Please help!
MTY Mouse is offline   Reply With Quote
Old September 27th, 2008, 06:02 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
could be a squeeky sway bar bushing, or shock mount. lay under the truck and have someone bounce the back end so you can pin point the noise.
Old September 27th, 2008, 07:29 PM   #3
MTY Mouse
MTY Mouse's Avatar
I will do so, thinking of spaying the sway bar bushing with wd to see if that makes a difference, will keep you posted.
Old September 27th, 2008, 10:30 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
look up there and see if the coil isolator fell out.
Old September 28th, 2008, 08:01 AM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
that and make sure the trailing arm bolts are tight to spec. I have seen the sleeve in the bushing drive people crazy trying to find out it was loose.
Yetti
Page generated in 0.18956 seconds with 38 queries
