97 ford ranger prerunner - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2008, 08:25 PM   #1
86scottsdalek10
86scottsdalek10's Avatar
Default 97 ford ranger prerunner
does anybody have any experience with throwing the fiberwerx or similar fiberglass fenders on vehicles? i was curious as to some pics or info on it since i bought the truck from a guy on this site it seems as if i need to take the cut off wheel to the inner fenders to get some more clearance....im looking at a kit to have 14-16" of wheel travel and i dont see how its possible unless i clear up some room to have the tires cycle up towards the hood...any info is appreciated...
86scottsdalek10 is offline   Reply With Quote
Old September 27th, 2008, 11:53 PM   #2
88mudder
In the band!
www.therangerstation.com has info on it, i believe the Tech Library.
Old September 28th, 2008, 04:05 PM   #3
xploder25
All American Nightmare
xploder25's Avatar
try www.dezertrangers.com
Old September 29th, 2008, 02:49 PM   #4
chris1044
chris1044's Avatar
1) this should be in the "ford" section...it'd get more reply's there.
2) typically glass fenders require the removal of the fenders/inner fender wells, though with some you can modify them to keep fender wells to prevent shit from being thrown into the engine compartment.....is this a 2wd truck or 4x4?
Old September 29th, 2008, 04:56 PM   #5
86scottsdalek10
not so worried about stuff getting onto the engine but i bought the truck the way it is and it looks like i need to trim the inner fenders with a cut off wheel regardless of if i go higher or not....theres just no room for travel and its 2wd....is that your truck in the avatar?
Old October 6th, 2008, 10:24 AM   #6
chris1044
chris1044's Avatar
the easiest way to figure out what you're going to have to trim is to put the truck on jack stands/hoist so the suspension is at full droop...then use a floor jack to push the suspension up (I use a trans jack or stand and lower the hoist)...mark where the tire hits, and trim away.
I don't have any pics on it, though I'm sure you can find them at dezertrangers.com. And more so, it's hard to trim for travel when you're not 100% sure how much travel you'll have and exactly where the wheel will travel since you don't have a kit on the truck...
Old October 6th, 2008, 07:54 PM   #7
86scottsdalek10
thanks i appreciate it but i believe now that the inner fenders are left on the vehicle and only very minor trimming if any is needed when i put the long travel kit on it.
Page generated in 0.20993 seconds with 44 queries
