can any one tell me what these codes are - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2008, 05:33 PM   #1
jared
Can't Worry About It
jared's Avatar
Default can any one tell me what these codes are
its a 96 gmc 1500 pickup 4.3 v6 and auto trans
my cheap scanner cant tell me what these 2 are
p1351
p1870
thanks
jared is offline   Reply With Quote
Old September 26th, 2008, 05:34 PM   #2
jared
jared's Avatar
Default can anyone tell me what these codes are
p1351
p1870
thanks
also posted in chevy tech.
Old September 26th, 2008, 05:45 PM   #3
Icemanii
GLFWDA Land Use Committee
Icemanii's Avatar
p1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
p1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
thanks
Found here:
http://www.troublecodes.net/OBD2/Pcodes.shtml
Good luck, hope this helped.
Icemanii is offline   Reply With Quote
Old September 26th, 2008, 05:49 PM   #4
MrGrey
propane evangelist
MrGrey's Avatar
you should double post it - that will help http://www.greatlakes4x4.com/showthread.php?t=105624
MrGrey is offline   Reply With Quote
Old September 26th, 2008, 08:38 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Don't do that again.
Page generated in 0.19951 seconds with 38 queries
