S-10 5 speed shifting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2008, 09:48 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default S-10 5 speed shifting
having a difficult time getting my truck to go into gear from a dead stop. thinking bent input or messed up pilot bearing. both good possibilities. will shift fine once moving. has brand new clutch that grabs at 1/2 way and it fully released at 3/4 up so i doubt thats the problem. could low fluid cause same problem? haven't checked it yet but i'm sure it's alittle low.
Old September 25th, 2008, 10:15 PM   #2
Tom
Because racecar
Tom's Avatar
Low fluid, internal / external master & slave cylinder leaks can cause the problem, Bad syncro, pilot bearing ect....
Old October 1st, 2008, 11:48 PM   #3
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Does it have ATF in it or heavy gear lube?
Old October 2nd, 2008, 07:51 AM   #4
Cartman
Can't lose with 42s
Cartman's Avatar
With the vehicle turned off does it go into gear?
Cartman is offline   Reply With Quote
Page generated in 0.20595 seconds with 35 queries
