f-150 front springs -or- how to lift for cheap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2008, 12:03 PM   #1
cjric
cjric's Avatar
Default f-150 front springs -or- how to lift for cheap
I need a set of front springs for my truck and am wondering what ones to put in. Are the 4x4 rated higher than the 4x2 ones? How about ones from a V8
(it's got the 300-6 in it.)? I figure if I need to replace them anyways, I might as well lift it a little as long as I can do it cheap.
cjric is offline   Reply With Quote
Old September 24th, 2008, 12:20 PM   #2
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
throw f250 springs in there, then if you are lucky you can still get it aligned.
Otherwise rough country (iirc) has a 1-2.5" kit with springs and drop brackets.
This is all assuming you are working with ttb.
mooseracing is offline   Reply With Quote
Old September 24th, 2008, 02:02 PM   #3
cjric
cjric's Avatar
yep. ttb two wheel drive. Not looking for anything more than an inch or two. Just something to keep it from looking like a saggy 'ole grandpa truck. :) Just going to run stock size tires.
Found out along w/ the right front broken spring, I also have a broken left rear shackle hanger.
Old September 29th, 2008, 06:36 PM   #4
Rulebreaker
Cadillac Jeeper/ RPM
Rulebreaker's Avatar
You can put shims under the springs when they sag. Stack of washers will work. RB
Rulebreaker is offline   Reply With Quote
Old October 6th, 2008, 09:09 AM   #5
fsumotorhead
N8KVB
fsumotorhead's Avatar
Use eddie bauer springs, they are slightly longer and have a better ride.
Old October 6th, 2008, 01:05 PM   #6
bj house
bj house's Avatar
Eddie Bauer springs in a F150?
Not sure about the newer ones but the 2wd's that I have seen (76-79) have smaller cups on the axle that accept the spring..
Old October 7th, 2008, 08:19 AM   #7
fsumotorhead
N8KVB
80-96 F-150s can use the 94+ Eddie Bauer F-150 springs, i was unsure of the year of the truck in question. if its 80 or older they won't work
Old October 8th, 2008, 08:31 AM   #8
bj house
bj house's Avatar
ah I thought that they only made a Eddie Bauer explorer. I suck 0-2 in the tech this week
Page generated in 0.29025 seconds with 47 queries
