hacking off a spindle and putting a new one on? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2006, 03:41 PM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default hacking off a spindle and putting a new one on?
Is there a special proceedure for hacking off a spindle and putting a new one on? I have those rims with the 6 or 8 thingy's around the tire that hold it on....like a semi tire and want to convert to regular 5 bolt stuff. TSC has everything I need to do it, spindle, brakes, drums, hubs and bearings....just not sure about removing the old spindle and putting a new one on.
Old May 2nd, 2006, 09:56 AM   #2
Mclovin
"The Situation"
Mclovin's Avatar
Arew you sure it doesnt just press out ? I think the TSC spindles are a press in type.. but your trailer may be different..
Old May 3rd, 2006, 11:12 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If you are going to buy all the stuff to convert. They sell complete axles for $250 at TSC. Yes the spindles are press and weld. But if they are not straight when done. You will wear tires out in no time at all. I had a cracked spindle on mine. Cut and rewelded it up. It works fine, but I have towed a couple hundred miles and I already need a tire. My next step is a new axle.
Page generated in 0.14238 seconds with 32 queries
