8" Steel Cylinder / Tube or Similar. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2008, 02:03 PM   #1
Mr.Green
I can levitate!
Mr.Green's Avatar
Default 8" Steel Cylinder / Tube or Similar.
I am looking for a steel, thin walled, 8 cylinder. It needs to be at least 12 long or so. Looking for ideas or objects that might be able to be modified to look like an oil tank for my motorcycle. It will hold the battery but look like an oil tank. I could make one from scratch, but there must already be something out there that might work. It needs to be 8" (or at least real close).
Old September 22nd, 2008, 02:05 PM   #2
jeepnxj96
jeepnxj96's Avatar
get a stove pipe and paint it
Old September 22nd, 2008, 02:37 PM   #3
Mr.Green
I can levitate!
Mr.Green's Avatar
Needs to be some what substantioal wall thickness for modifying. 1/8" or so. Is stove pipe even steel?
Old September 22nd, 2008, 02:40 PM   #4
steveo
In the band!
yes, but uber thin. if you were closer i would let you dig through my shop yard, you would find something.
Old September 22nd, 2008, 04:04 PM   #5
Yota Bill
I'll look around at work, but everything there will probably be too heavy of a wall for what you want...
Old September 23rd, 2008, 11:28 AM   #6
Mr.Green
I can levitate!
Mr.Green's Avatar
Thanks for looking fellers. Still need somthing! BTT
Old September 24th, 2008, 12:55 PM   #7
Mr.Green
I can levitate!
Mr.Green's Avatar
Ttttttttts
Old September 24th, 2008, 10:13 PM   #8
Yota Bill
damn, got busy and forgot about this again...I have a good idea of what you can use though...steel air intake tubing...should be able to find something close to that diameter, and hopefully a good straight section at least 12 inches long..and its probably1/16 wall or so...
Old September 25th, 2008, 08:46 AM   #9
Mr.Green
I can levitate!
Mr.Green's Avatar
That would be GREAT! I appreciate it. Let me know. Thanks!
Old September 25th, 2008, 08:56 AM   #10
1badzuk
1badzuk's Avatar
take 2 coffee cans cut ends and fiberglass them instant light weight tube
1badzuk is offline   Reply With Quote
Old September 25th, 2008, 11:15 AM   #11
fsumotorhead
N8KVB
fsumotorhead's Avatar
How about a mini keg?
Old September 25th, 2008, 11:18 AM   #12
buddha
playing life by 'ear'
buddha's Avatar
I am looking for a steel, thin walled, 8” cylinder. It needs to be at least 12” long or so. Looking for ideas or objects that might be able to be modified to look like an oil tank for my motorcycle. It will hold the battery but look like an oil tank. I could make one from scratch, but there must already be something out there that might work. It needs to be 8" (or at least real close).
8" schedule 5 pipe (8-5/8" od .109" wall)
buddha is offline   Reply With Quote
Old September 25th, 2008, 12:49 PM   #13
SuperYooper
Thread killer
SuperYooper's Avatar
I have an air tank that I bought for on board air from Kilby that is about 8" diameter (maybe a little less), but it is pretty thick-walled I think. Just a thought, I'm not giving you mine.
**edit: here it is
Kind of pricey though if your just going to cut it up.
SuperYooper is offline   Reply With Quote
Old September 25th, 2008, 12:52 PM   #14
SuperYooper
Thread killer
What about a "retired" scuba tank, or a nitrous bottle? Could probably pick up an old scuba tank from a dive shop...
Old September 25th, 2008, 01:04 PM   #15
Mr.Green
I can levitate!
Mr.Green's Avatar
Air / nitros tanks might work, but they are way thicker than I would need. I think a couple of these suggestions might be the ticket!
Page generated in 0.24435 seconds with 68 queries
