96 Olds Cutlass Supreme - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2008, 03:53 AM   #1
84ramcharger
sim sim balla bim
84ramcharger's Avatar
Default 96 Olds Cutlass Supreme
When driving the car, if I make a left turn then drive straight it will pull to the left. If I make a right turn then drive straight it does not pull at all. I replaced the calipers, rotors, and drivers side hub assembly. Could this be a cv issue, or maybe a strut? BTW I replaced all the parts because they were bad not throwing parts at it.
What do you guy's think? Thanks
84ramcharger is offline   Reply With Quote
Old September 22nd, 2008, 06:28 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
is all the steering linkage tight?
Old September 22nd, 2008, 07:37 AM   #3
84ramcharger
sim sim balla bim
Yes, everything is tight and working properly. When I did all the brake work I checked it all out and made sure, then greased everything.
Old September 22nd, 2008, 07:25 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
rotate the tires front to back and see if it still pulls. thats usually my first approach with a pulling problem.
Old September 23rd, 2008, 04:06 AM   #5
84ramcharger
sim sim balla bim
I just had brand new tires put on the front. So I do not think that is going to help.
I am going to look at the front end again this weekend, maybe I missed something.
Old October 14th, 2008, 12:28 PM   #6
84ramcharger
sim sim balla bim
All fixed, it was the strut bearings.
Page generated in 0.25228 seconds with 41 queries
