who has the best water - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2008, 07:35 PM   #1
XXXJ
Desert Rat
XXXJ's Avatar
Default who has the best water
What lake is the flatest?
i.e. less effect from wind, for going fast
Old September 21st, 2008, 08:08 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
huh
Old September 21st, 2008, 08:09 PM   #3
KartRacer
Blowd up
KartRacer's Avatar
Originally Posted by hosejockey4506 View Post
huh
x2
River?
Old September 21st, 2008, 08:13 PM   #4
kickstand
circling the drain
kickstand's Avatar
Yes
Old September 21st, 2008, 08:15 PM   #5
XXXJ
Desert Rat
XXXJ's Avatar
Lake or river..
Least amount of chop.
Back in the day we would go to the Sacramento Delta and ski the channels.
Like glass because the levies block the wind.
Old September 21st, 2008, 08:18 PM   #6
Bones
Bones's Avatar
mah bathtub
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 21st, 2008, 08:24 PM   #7
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you would have to do the rock test to find out which lake has the heaviest water. You need to toss a 1lbs rock 8ft in the air and land in at least 1ft no more than 5ft of water...then if the ripple pattern stays under 10ft you are good to go for a fast water lake, if the pattern is over 10ft it's not good for high speed runs, but better for skiing becasue the water is softer...good rule of thumb the hard the water the faster the boat will run and the calmer it will be as wind has a hard time affecting it.
Old September 21st, 2008, 08:36 PM   #8
kickstand
circling the drain
kickstand's Avatar
did you ever make it to casey's last night?
Old September 21st, 2008, 10:34 PM   #9
Christmas Cookie
ya, you gave me a 5 second frencher...duh...
Old September 22nd, 2008, 05:21 AM   #10
The flattest lakes are in the desert where there are no hills. Here in Michigan where it is hilly, all the lakes go up or down hill.
Old September 22nd, 2008, 04:34 PM   #11
kickstand
circling the drain
kickstand's Avatar
oh, u must have gotten sloppy 5ths.
Page generated in 0.21157 seconds with 56 queries
