1977 Blazer Crossover Steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2008, 12:33 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default 1977 Blazer Crossover Steering
1977 K-5 blazer
4" Rough Counrty lift
36" TSL's
Dana 60 front
Will it hit the crossmember or not?? I've read it does hit and other people say it doesn't. Anoyne running it and did you have to make a new crossmember?? And i have a 3" spacer block on it right now on the driverside and stock steering setup, should i put the block on the other passanger side along with the new crossover steering??
Old September 17th, 2008, 12:35 PM   #2
boggin-machine
boggin-machine's Avatar
what kind of cross over kurt? tre or heims. im asuming that you got the high steer arms as a kit.
Old September 17th, 2008, 12:57 PM   #3
Hoss Blazer
!SPARTY ON!
I will be running a stock pitman and w/ a heim on the drivers side and a regualr tie-rod on the passanger side or a heim joint!
Old September 17th, 2008, 01:19 PM   #4
boggin-machine
what kind of arms dd you get?
Old September 17th, 2008, 02:01 PM   #5
Hoss Blazer
!SPARTY ON!
I'm gonna get the KOZ offroad arm for the knuckle that just sites over the top of the cap,and get a moog pitman arm thats off a 1981 chevy 2wheel drive truck cuase thats what the steering box is off of.
Hey you gonna come pic the tires up or what??? lol Wheelingmachine
Old September 17th, 2008, 09:58 PM   #6
boggin-machine
i talked to you about them tonight. thanks kurt.
Old September 23rd, 2008, 08:03 PM   #7
Hoss Blazer
!SPARTY ON!
Anyone know???
Old September 24th, 2008, 08:35 PM   #8
jhnyquest
goof ball
jhnyquest's Avatar
I have crossover hydro assist setup on my buggy. It is not a stock setup in the front end but very close to it. I had to trim a very small amout of the crossmember out. Small enough that I felt reinforcement was not necessary.
Page generated in 0.15440 seconds with 47 queries
