ford U-joint size problem. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2008, 11:32 AM   #1
FORDMAN49450
FORDMAN49450's Avatar
Send a message via Yahoo to FORDMAN49450
Default ford U-joint size problem.
ok I have a 94 ext cab ranger 4x4 with 4.0, M5OD Trans with a electronic shift transfer case. MY current driveshat is a 2 piece with a midship bearing. I am wanting to convert it to a 1 piece driveshaft. I found a driveshaft that fits perfectly as far as length goes. I am going by an tech article at www.therangerstation.com which states I can replace the u-joint to make it work or try to find a flange for the transfercase. I cannot find a flange. I bought a 1 piece driveshaft for a 98 ranger ext cab. The rear flange for the axle bolts right on but the front where it bolts to the transfercase is a bigger bolt pattern then the transfercase flange. I was going to change the end on the driveshaft from the old to the new but the U-joints are different. the old driveshaft has a u-joint that is 3.25" approx from cap to cab on both axis's. without the caps it is approx 3". the new replacement driveshaft ujoint is 3 5/8 from cap to cap or approx 3 5/16 without the caps. the caps on both driveshafts are 1 1/16. SO I guess I need to get a u-joint that is the same on one axis as the old driveshaft and the other axis needs to be the same as the new one so I can put the old driveshaft flange on the new one. If anyone can give me a part number this would be great as none of the parts stores here are of no help at all even with measurements. Thanks.
FORDMAN49450 is offline   Reply With Quote
Old September 17th, 2008, 11:58 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Sounds like you need a 1310 to 1330 conversion joint. Should be able to go into a local auto store and get one (ask for a conversion u joint, they will get mad because they will have to open one of them dusty books they got )
Page generated in 0.23249 seconds with 29 queries
