12.5:1 compression - what octane? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2008, 01:39 PM   #21
PavementPounder
PavementPounder's Avatar
Originally Posted by four_by_ken View Post
Who the hell talked her into this one?
ClarkstonCracker.
Old September 16th, 2008, 01:51 PM   #22
clarkstoncracker
lol
clarkstoncracker's Avatar
Originally Posted by PavementPounder View Post
ClarkstonCracker.
x2. I had some junk amc parts sitting in my garage, and nobody to buy them. so I found a girl who doesn't know much about engines and sold her all the junk for top dollar.
Old September 16th, 2008, 03:43 PM   #23
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
Location: Muskegon Mi. http://www.mymudlife.com/profile/MIkeyWells
Send a message via Yahoo to Mikey1258
oo..call me next time, I love paying too much for junk amc parts.
Mikey1258 is offline   Reply With Quote
Old September 16th, 2008, 03:53 PM   #24
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
how much advance are you running?
Just go up in octane until the spark knock goes away, or retard the timing.
Old September 16th, 2008, 03:58 PM   #25
scotte
one word ............... E85 :)
scotte is offline   Reply With Quote
Old September 16th, 2008, 04:06 PM   #26
PavementPounder
Would you prefer we discuss how she really got her $250 401? It was easier to just pin it on you.
Old September 16th, 2008, 04:15 PM   #27
Man, if its really that high, and you don't want to tear it up, I would be looking at running E85 or Propane or something.
I have run 11.3:1 on 93 successfully, but that was an aluminum head, big cam honda motor with some tuning.
12.5:1 on an iron head 70's V8 in a Jeep seems like a real recipe for disaster.
Old September 16th, 2008, 04:24 PM   #28
PavementPounder
She texted me earlier and confirmed they are 1974 58cc heads and not the 52's, so that'll be helpful here.
Old September 16th, 2008, 06:46 PM   #29
So, is the 12.5:1 a guess, or was it calculated off something?
Were the heads actually cc'd? What about the block/piston/rod/crank combo..... any idea how much much piston volume there is at TDC?
Old September 16th, 2008, 06:51 PM   #30
clarkstoncracker
lol
the thing runs pretty damn perfect, just need to advance timing slightly but can't because of the distributor hitting the power steering pump. have rotate it a tooth. also have to put in some smaller jets..
Old September 16th, 2008, 07:08 PM   #31
PavementPounder
The 12.5 was an "estimate" that someone shit somewhere along the way. I wasn't clear on whether it was the piston supplier or the engine builder, but it didn't really sound like it was based on any math. I asked her about some of the different things she had done that could increase or decrease compression, but it doesn't sound like all that stuff was recorded. Probably won't get a real number without pulling a head and measuring, but it doesn't sound like that's necessary so far.
She also mentioned that while the block was decked and the heads were milled, the intake was not. Not sure if enough was taken off for it to matter as she didn't recall any numbers from memory, but the intake can always be fixed later.
It may run fine now, but it was always a different story under load on all the AMC V8's I've had. Hopefully the fact that it has the larger chambers will give enough of a cushion to run on 93 and she can put in something higher and advance it for "special occasions".
Old September 16th, 2008, 07:21 PM   #32
1crazyredneck
MichiganRednecks
1crazyredneck's Avatar
Wonder what pistons are in it.. I guess I'd try it and take care with the right foot till you know it isn't gonna knock.. If they are Hyper KB's then they won't take much knocky knocky till they come apart.. forged will give you a "little" more room for error but not much. Just for giggles I'd be curious to see what the compression gauge says.. Not that it's 100% accurate in determining compression ratios it will tell you if it's "really high"
Here is a link that is kinda helpfull.. Again not 100% accurate but at least it'll give you a idea of what you have.. big thing you need to have is the cam duration and rod to stroke ratio..
http://www.not2fast.com/turbo/compre...pressure.shtml
1crazyredneck is online now   Reply With Quote
Old September 16th, 2008, 07:30 PM   #33
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
IMHO, and not what you want to hear, but if you can't get 93 to run it'll be worth a quick teardown (just pull the heads) and take some measurements to get a better idea. you'll be able to figure out if you can get away with a bigger head gasket.
BTW,
smaller jets will only increase knock. I wouldn't mess with carburetion without having a WRAF sensor.
@clarkstoncracker
Old September 16th, 2008, 11:34 PM   #34
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
kelly i have a wide band somewhere's we could tune it
Old September 17th, 2008, 12:16 AM   #35
88mudder
In the band!
The Edelbrock website has a sweet jetting chart PDF file for them carbs. Ive followed the charts on my carb and got the calibration kit..real quick and easy to tune!
Old September 18th, 2008, 07:01 PM   #36
Leanz
Full taste of tender
Leanz's Avatar
we've allready decresed the richness 8% according to edelbroks calibration pdf needs get the next size smaller jets still, but I dont think my compression is 12.5:1 anymore...
pistons 10.5:1 (not sure if that was for 52cc heads or the 58cc. I have 58cc)
block decked and bored .030
heads milled/port/polished
edelbrok preformer intake that was not milled down
head gaskets are felpro, but I dont remember choosing a thickness..
HEI distributor
.010 off the crank I think
CAM:.490/.490 lift with 1.6 rocker ratio
110 degree lobe separation
RPM power range 2000-6000
oh .. and of course its not going to be a DD, I have a mustang DD
Leanz is offline   Reply With Quote
Old September 18th, 2008, 07:09 PM   #37
PavementPounder
These are her pistons.
Old September 18th, 2008, 07:17 PM   #38
1crazyredneck
MichiganRednecks
Those look like a Dish?? I'd say you'll be fine.. I say get some brakes and give it a run.. :)
Old September 18th, 2008, 07:20 PM   #39
PavementPounder
Yup. I'm thinking that they have have been intended for the 52cc heads. Not too concerned about the compression anymore. Once the motor is timed, it would be nice to check the cylinder pressures.
Old September 18th, 2008, 07:27 PM   #40
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
those have a big dish there is no way its 12 to 1. with a flat top maybe but not with those
samurai2240 is offline   Reply With Quote
Page generated in 0.46048 seconds with 84 queries
