12.5:1 compression - what octane? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2008, 10:45 AM   #1
Leanz
Full taste of tender
Leanz's Avatar
Default 12.5:1 compression - what octane?
Anyone know what octane I should be running?
Leanz is offline   Reply With Quote
Old September 16th, 2008, 10:50 AM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I'd start with premium and if it knocks, move up to some 105
or go propane
Old September 16th, 2008, 11:00 AM   #3
Bones
Bones's Avatar
93 with correct timing.
I seriously doubt you want to run race fuel all the time, but I might be wrong.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 16th, 2008, 11:03 AM   #4
insane88yj
insane88yj's Avatar
Most Likely 110 Its What I Have To Run But Mine Is Litel Higher Comp. Which Is Or Close To $6 Gal.
insane88yj is offline   Reply With Quote
Old September 16th, 2008, 11:06 AM   #5
Aluminum heads? Iron heads? What kind of cam? Dymanic compression?
Old September 16th, 2008, 11:11 AM   #6
PavementPounder
PavementPounder's Avatar
Factory AMC iron heads, which should be 58cc on her motor. It would have cost me more if they were 291's, so I doubt they are.
Old September 16th, 2008, 11:13 AM   #7
MrGrey
propane evangelist
MrGrey's Avatar
or go propane
x2
propane has a 104 octane rating
MrGrey is offline   Reply With Quote
Old September 16th, 2008, 11:41 AM   #8
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
Location: Muskegon Mi. http://www.mymudlife.com/profile/MIkeyWells
Send a message via Yahoo to Mikey1258
Ethanol, rejet carb.
Mikey1258 is offline   Reply With Quote
Old September 16th, 2008, 11:42 AM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
is that your actual CR (measured), or a guess on what you should have? what ever made you want to run 12.5:1?
@clarkstoncracker
Old September 16th, 2008, 11:47 AM   #10
PavementPounder
Just talked to her about this on the phone. The motor should be late-70's, so that number may be high. She's going to verify the head casting and then look up the amounts of material removed from the heads & block, as well as try to get some specs on the pistons. The pistons *may* have been rated for 52cc heads in their description, so she may not be quite as high as 12.5:1.
Old September 16th, 2008, 11:56 AM   #11
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
Anything over 10 seems to run poopy on 93. In my experiance anyway, lets face it checking timing ever or even every other time you hit the trail is a huge PIA. I do it on my race motor all the time,and I hate it.
Old September 16th, 2008, 12:03 PM   #12
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
http://www.qrckarts.com/store/index..../313/index.cfm
Check bottom of page.
Old September 16th, 2008, 12:22 PM   #13
four_by_ken
Need a strap?
four_by_ken's Avatar
Someone get a real good deal on a motor or something? Not really an all around motor for wheeling by the sounds of it so far.
four_by_ken is offline   Reply With Quote
Old September 16th, 2008, 12:52 PM   #14
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Remember you need to take into account the head gasket thickness.
Convert to run E85, problem sovled.
Old September 16th, 2008, 12:55 PM   #15
PavementPounder
It was stock when she got it.
Old September 16th, 2008, 01:00 PM   #16
four_by_ken
Need a strap?
So, what is the intended purpose of this Jeep? (I dont feel like reading the 100 page thread to get caught up). Last time I saw it... it was purple or something and getting torn apart. I think I helped get it to her parents house or something with Bill.
Old September 16th, 2008, 01:12 PM   #17
PavementPounder
Its going to be a daily driver.
Old September 16th, 2008, 01:23 PM   #18
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Originally Posted by MrGrey View Post
x2
X3
Although usually propane is deemed to have up to 110 octane. And cheaper than gas by about a dollar
Nuzzy is offline   Reply With Quote
Old September 16th, 2008, 01:23 PM   #19
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I can hardly get away with running 93. If i'm really heavy into the gas it has some spark knock. I can't afford to DD that thing.
I hope you have a ton of money linz to feed the best!
E85 is 110....
Old September 16th, 2008, 01:32 PM   #20
four_by_ken
Need a strap?
Who the hell talked her into this one?
Page generated in 0.39948 seconds with 84 queries
