Towing Safely? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2008, 10:08 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default Towing Safely?
If I put an XJ and a YJ on a gooseneck trailer, can I safely tow it with an F-250 light duty 4x4? The light duty means it has bastard wheels (7 lug) LD springs, and a wonderful 5.4.
If not, would an 08 Super duty 5.4 crew cab be better?
Old September 15th, 2008, 10:14 PM   #2
DocRamcharger
It all comes down to GVWR and GCWR. If you are over the limits and get stopped, bad news.
DocRamcharger is offline   Reply With Quote
Old September 15th, 2008, 10:16 PM   #3
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
how heave is the hole combo, some trailer big enought o hold 2 rigs weigh 8-9k so if its a heavy one that no you would be over the limit and get busted
scramblerman72 is offline   Reply With Quote
Old September 15th, 2008, 10:17 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
i wouldnt do it..
The light duty 250's seems like nothing more than an F-150 to me..
the axles offer no major beef. the drivetrain is to weak to be considered a 2500..
the light duty 250 is the Ford version of the GM's 1500HD I.M.O
The super duty crew cab will handle that load MUCH easier.. the extra Wheelbase will have thanking god !
Old September 15th, 2008, 10:19 PM   #5
HVYRTFT
Reed my teef
HVYRTFT's Avatar
That's what I was thinking. And since it's a long trip, I know it would happen, so I better check it out. I figure the two jeeps weigh in at roughly 6000LBS (shooting high) and I'm guessing the trailer is around 3000LBS. But I'm not sure what the GVWR's are of the trucks and if they can handle it. Anyone have a guess?
Old September 15th, 2008, 10:22 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
So ruling out the F-250 LD, Would the 08's 5.4 have enough power? Did anything get changed or is it the same old 5.4? Cause we all know what those can do.
Old September 15th, 2008, 10:25 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
Your biggest issues is braking ability.. the engine will pull the load it will just take you longer to get up to speed
Old September 15th, 2008, 10:26 PM   #8
HVYRTFT
Reed my teef
HVYRTFT's Avatar
awesome. Tow command and brakes on both axles should help. Thanks people!
Old September 15th, 2008, 10:30 PM   #9
DocRamcharger
You should be able to get the GVWR numbers from the door tag.
Old September 15th, 2008, 10:32 PM   #10
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Right on, I'll have to check it out in the a.m.
Old September 16th, 2008, 12:06 AM   #11
brimy311
Smells like a Fork Liftis
brimy311's Avatar
With a 24-26' trailer, an XJ and a YJ, you will be near 14K. I would not even try to pull that with a gaser in would be miserable.
JcrOffroad.com
Like us on Faceook!
Old September 16th, 2008, 02:51 AM   #12
busyfixin
Balls Deep
busyfixin's Avatar
you should be fine with the superduty. i wouldnt use the light duty. being a gasser will suck compared to a diesel, but thats the case with almost every vehicle on earth.
Old September 16th, 2008, 10:05 PM   #13
2kids=nojeepmoney
i'd say you're shooting LOW, not high. both vehicles in STOCK form weigh 3000# plus.
2kids=nojeepmoney is offline   Reply With Quote
Old September 17th, 2008, 10:09 AM   #14
CreativeFab
used to be Ironman
CreativeFab's Avatar
My CJ7 fiberglassbody loaded with tools is 4650, so your shooting low
head over to your local elevator and get the thing weighed if your are in doubt
And the 5.4 will hate you and you hate it, especially if you encounter any incline on your journey. Like Brimy said, your around 14k
Old September 17th, 2008, 10:39 PM   #15
HVYRTFT
Reed my teef
HVYRTFT's Avatar
ha, I guess my math was a little off. Thanks for the corrections, folks.
Old September 17th, 2008, 10:49 PM   #16
kickstand
circling the drain
kickstand's Avatar
I would do it, in fact I would do it with a half ton, but hey whatever
Old September 17th, 2008, 11:01 PM   #17
Nuggets
I fix stuff!
Nuggets's Avatar
I've towed waaaaayyyyy more than I should have with a half ton cheby with a 6.2 diesel. Life was suckin' pretty hard during the tow.
Old September 18th, 2008, 07:50 AM   #18
KartRacer
Blowd up
KartRacer's Avatar
Just as Brimy said, with a gasser it is going to suck. But sometimes you have to do what you have to do. As long as you have a brake controller. No need to be in a hurry.
For the legality of it, check the weight rating of the trailer (I doubt that will be an issue), and the axle rating of the truck and rear tires. Then you need an idea of the pin weight of the trailer when loaded. That can be adjusted, if the trailer is long enough to move the vehicles a bit.
If you were to be pulled over, those would be the issues, not the GVWR and GCWR. Those two numbers would come into play if you were involved in an accident, and not by the cops, but by an insurance company and lawyers.
Old September 20th, 2008, 08:58 PM   #19
1crazyredneck
MichiganRednecks
1crazyredneck's Avatar
You can always pull it to a near by scale and weigh it all if you think your over..
1crazyredneck is offline   Reply With Quote
Old September 20th, 2008, 09:03 PM   #20
junk90xj
ALLPRO AUTO
junk90xj's Avatar
agreed i couldnt even imagine trying to haul all that weight with a gasser.
thats a good way to kill a truck.
http://www.apalansing.com/
Page generated in 0.33648 seconds with 83 queries
