TJ axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2008, 08:29 PM   #1
jeepnmustang
jeepnmustang's Avatar
Default TJ axle
i have a 2004 TJ that i took up to the dunes and i bent the axle jumping i need an axle asap for it ..let me know thanks -matt
jeepnmustang is offline   Reply With Quote
Old September 15th, 2008, 08:30 PM   #2
jeeperbrian
GLFWDA member
im assuming your looking for a front d30?
Old September 15th, 2008, 08:53 PM   #3
jeepnmustang
yah a d30
Old September 15th, 2008, 09:56 PM   #4
Pete M
Comanche Addict
Pete M's Avatar
What gear ratio?
Pete M is offline   Reply With Quote
Old September 16th, 2008, 07:00 AM   #5
2kids=nojeepmoney
Originally Posted by Pete M View Post
What gear ratio?
that's not important.
2kids=nojeepmoney is offline   Reply With Quote
Old September 16th, 2008, 07:28 AM   #6
xjmichigan
xjmichigan's Avatar
It is if he does not want to swap gears.
Old September 16th, 2008, 08:56 AM   #7
scotte
i have a high pinion d30 (from an xj) forsale for $100 in the forsale section
it has the stronger reverse cut gear (3.55's)
it is considered and upgrade compared to the standard d30 you have (esp. a bent standard d30)
scotte is offline   Reply With Quote
Old September 16th, 2008, 11:24 AM   #8
2kids=nojeepmoney
it must not be if he not only doesn't specify the gear ratio, let alone what axle he needs (front/rear, D30, D35? D44?)
Old September 21st, 2008, 11:39 PM   #9
JDirt
Always right-sometimes
JDirt's Avatar
I've got one for you. $50
JDirt is offline   Reply With Quote
Page generated in 0.17990 seconds with 50 queries
