How can tire height be so "off"? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2005, 05:51 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default How can tire height be so "off"?
I just purchased a set of 37x13x15 boggers. They measure 38.5" tall and 14" wide fully inflated.
If I wanted those sizes, I would of purchased them.. How can these measurements be so far off?
Old November 16th, 2005, 07:58 PM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thats interesting, cause the people who I have talked to with that size bogger said they were only 35.5" tall.
Old November 16th, 2005, 08:03 PM   #3
xjmichigan
xjmichigan's Avatar
Originally Posted by clarkstoncracker
fully inflated.
haha 100psi?
Old November 16th, 2005, 08:04 PM   #4
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
depends on the width of rim they are on as well... for instance my 33x12.5 dunlops measure 33" tall (never measured width) on an 8" rim... my buddy had the 35" version, his measured 33" tall on a 10" wide rim, on an 8 they measured just shy of 35"
Old November 16th, 2005, 08:06 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you do a little checking you will find that tire height is based on the CASING size minus the tread, its added. the normal depth is about 12/32 in a passenger car tire and 21-24/32 on an off road tire.
Yetti
Old November 18th, 2005, 02:16 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
They're supposed to measure 36.8" tall, 13.7" wide (not tread width but cross-section) on a 15x10 rim.
According to Interco, the only tire that comes close to 38.5" tall and 14" wide would be the 38.5" tires.... You didn't get the wrong size, did you? (I know, I know, but someone had to ask!)
Old November 18th, 2005, 02:43 PM   #7
There's always a pretty big variability, usually they are smaller, although a few swampers are known to run quite a bit bigger.
My last jeep I ran 35x12.5 SSR radials on 15x8" rims up front, and 35x14.5" Boggers on 15x10" rims out back... the SSRs were over an inch taller than the boggers.
My current 36x12.5 SXs seem to measure out right at 36", although they are at 30psi... I'll drop them to 14 or so and see what they do. Stiff sons a bitches, might not compress much..
Old November 18th, 2005, 05:21 PM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Only in Bias tires will you see a large difference in diameter based on rim size. In a radial it's hard for it to get bigger based on construction.
Boggers run big.
**EDIT Brian says I'm a retard and boggers run small :tonka: so once again I am wrong **
JcrOffroad
Zoom Zoom!
Old November 18th, 2005, 08:40 PM   #9
35" boggers run small, I know that..
Old November 19th, 2005, 10:47 AM   #10
xjjeepthing
XJ Slut
xjjeepthing's Avatar
Send a message via Yahoo to xjjeepthing
Talking
I have Interco 31 trxus M/T's on my Jeep they measure right at 32" on an 8' rim.
xjjeepthing is offline   Reply With Quote
Old November 19th, 2005, 07:35 PM   #11
TopHeavy
Yikes!
TopHeavy's Avatar
Mine certainly did.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old November 19th, 2005, 08:00 PM   #12
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
The tires themselves will always be off depending on how they're measured and what not. The width of the wheel they're mounted on are also going to change the actual height and width of the tire as well.
Old November 20th, 2005, 07:45 AM   #13
noodles
give 'er sh*t ay?
noodles's Avatar
why are you complaining? id love to get a biger tire than what i payed for!!!! lol,but i couldnt fit 38"s on the dodge............yet
Old November 20th, 2005, 03:52 PM   #14
Cube
Captain of my pants
Cube's Avatar
yea, my 35 inch boggers were small like 34 if I knew that I would have went with 38 or 40
Cube is offline   Reply With Quote
Old November 21st, 2005, 07:31 AM   #15
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
CC's aren't the 35's they are the 37's and are the only swamper that is bigger then the size stamped on the tire. Yes the 35's were the only ones that went under the size stamped. All other swampers are true to there size. CC you were telling me you had 39's so I had them aired up to 200psi since they were short.
Old November 23rd, 2005, 10:51 AM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
38x12.5x15 swampers (not SX) run small, somewhere closer to 36".
33" bias run big, almost the size of a 35" radial.
Old December 5th, 2005, 06:18 PM   #17
davidbrady
where is darko when we need him, he has to have pics of all these tires next to eachother somewhere
davidbrady is offline   Reply With Quote
Page generated in 0.25979 seconds with 74 queries
