deisel question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2006, 03:01 PM   #1
4x4forlife
4x4forlife's Avatar
Default deisel question
hey guys I need some help.. ok so I went to go look at a truck today its a 1986 F-350 it has a 6.9 in it with a 4 speed and 4x4. it runs but you need to start it with starting fluid. he says its the glo-plugs. my dad happens to think this truck is crappy because you need to use starting fluid to start it. and he also dosent like the fact that it was blowing out some blue smoke at first until warmed up(it has straight pipes and it was cold out he wont listen to me) so what do you think it could be? keep in mind the engine & trans have 109,000 miles on them and he just replaced injectors.
4x4forlife is offline   Reply With Quote
Old April 30th, 2006, 03:19 PM   #2
jamiesann
jamiesann's Avatar
hmm i would ask why dont you just swap out the glow plugs ?
If he does and you see it runs you got a winner, price prolly goes up then though. *shrugs*
Do you know this guy well ?
jamiesann is offline   Reply With Quote
Old April 30th, 2006, 04:48 PM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
With diesels, if the glow plugs are crap, it won't start worth a damn - sounds right to me.
Also, if the glow plugs are shot, it'll smoke like crazy till it warms up - you're seeing (more or less) evaporated diesel (bluish white).
Old April 30th, 2006, 07:21 PM   #4
4x4forlife
4x4forlife's Avatar
hey guys thanks for all your help! ill try and convince the old man to let me get it!
Old April 30th, 2006, 08:09 PM   #5
PavementPounder
PavementPounder's Avatar
Just tell your old man that he doesn't know what he's talking about. That usually goes over well. :tonka:
Old April 30th, 2006, 08:15 PM   #6
yota85
yota
yota85's Avatar
yea its probly glow plugs
yota85 is offline   Reply With Quote
Old April 30th, 2006, 08:39 PM   #7
Bones
Bones's Avatar
be carefull, starting fluid in diesels will blow head gaskets.....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 1st, 2006, 03:17 PM   #8
Renegade II
Coil springs are for pens
Renegade II's Avatar
Glow plug relay, glow plug controller, glow plugs, lift pump, could be a few different things. Good luck getting the glow plugs out in one piece if they are swelled. If he claims it's such an easy / cheap fix why doesn't he invest the $90 to make it more sellable at a higher price?
Old May 1st, 2006, 05:30 PM   #9
chris1044
chris1044's Avatar
Because it's not....and IIRC glow plugs from ford can be rather expensive - maybe not for this engine though
Old May 1st, 2006, 10:27 PM   #10
Icebreaker88
Icebreaker88's Avatar
Glow plugs for a 95 PSD not sure if they are similiar are about 10-15$ each.
I would be a little hesitant about it not starting at all on its own.. You say it was cold out when you looked at it? How cold?. I can start my PSD with out the Glow plug relay hooked up, down to about 50*. Its not happy about it BUT it will start without it. And in the summer I can disconnect them and not notice it at all.
I would try to go start it on a decent temp day and see if it will start with out starting fluid.
Now that is also a older motor than I am running so everything I said may be useless.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old May 26th, 2006, 04:15 PM   #11
busyfixin
Balls Deep
busyfixin's Avatar
dunno if this is relevant anymore, but my 6.9 wouldnt start hardly at all without the glowplugs, even when it was warm out. glow plugs used to be about $9 each. an easy test you can do... turn the key on and off about 50 or 60 times, then start it. if it starts, you probably need a relay. take a multimeter, run ohms from the terminal on the top, and the engine block. it should have an ohms reading, or beep if yours does that. you could also take a socket with you, and pull a glowplug look and see if the end is all burned off.
busyfixin is online now   Reply With Quote
Old May 28th, 2006, 09:12 PM   #12
smasheromalley
smasheromalley's Avatar
Go here www.thedieselstop.com and search their 6.9 forum
More info than you could ever want to know about ford diesels. Saved my ass more than once.
Page generated in 0.23238 seconds with 59 queries
